View Full Version : Still confused on this oil and temp sensor deal.....
trapin
10-24-2007, 04:16 AM
Alright....so from what I've gathered so far....for oil pressure, I am going to want to buy a cover plate for my AutoKraft oil filter adapter (as justin did) and drill a hole into it to feed an Autometer oil sending unit for my "electronic?" oil pressure gauge. When done hooking that up I am guessing that the old oil pressure sending unit that is on the top/back of block behind the intake needs to be removed and plugged because it will no longer be needed. Am I correct?
Also...for the water temp gauge I am going to want to drill out the allen head plug on the one side to turn it into and adapter for a temp sensor "to be bought later". After that is done, what do I do with the factory temp sensor that was originally on the head on the opposite side that sent information to the PCM? Do I toss that and plug the hole? Do I need to necessarily drill out that allen head bolt to make it an adapter or can I just buy a whole kit? If the factory sender get's tossed and the old hole plugged, do those connections on my harness get edited out and my PCM edited to remove oil and temp?
Whew! I think that's everything.
Thanks.
parsonsj
10-24-2007, 05:26 AM
Tony, if you are using the factory PCM, you'll need to provide water temp to it. I'm not sure about oil pressure. I think you should plan on dual temp and pressure sensors. :(
jp
HILROD
10-24-2007, 06:25 AM
You'd need the stock senders for the stock pcm, unless you had them tuned out. It should need to see oil pressure.
Steve1968LS2
10-24-2007, 06:30 AM
Like John said you need to keep the factory water temp sender, the PCM needs it. The PCM DOESN'T need the oil pressure info.
Most people don't realise that you can also get oil pressure info from the block just behind the intake manifold instead of just plugging it up. This is where the factory gets the info. You just need the right fitting to make it work. I put a mech gauge on Penny in that spot just to have a back-up to my elec gauge. It's a good option if you can't get it (or it's a pain) down by the oil filter.
Drilling out an allen plug to adapt a water temp sensor is a bigger pain than it seems. By the time you drill a hole big enough for the sensor the wall gets pretty thin. If your hole is off then the wall will fail while installing. Autometer does make the right fitting, but the sensor barely fit and I had to grind it down a bit. The easiest thing to do (what I wish I would have done) would be to mill the hole larger when the head is off the car and use a standard size adaptor. You can only do this with the head off the engine though.
I haven't had my coffee so I hope that made sense.. lol
Steve1968LS2
10-24-2007, 06:32 AM
No, the PCM only takes oil pressure in to send it to the gauge cluster. It needs water temp, IAT, and such to adjust how the engine runs, but it doesn't require oil pressure info for the car to run.
It could cause a Check Engine light, but that's taken care of when the computer is reprogrammed to remove the VAT, and other "un-needed" functions.
camcojb
10-24-2007, 07:24 AM
As has been said you'll need two water temp sensors; one for the EFI computer and one for your gauge. I used the stock water temp sensor in the drivers front head and used the rear passenger one with an Autometer adaptor to install the Autometer sender for my gauge.
I also used an Autometer adaptor for the rear oil pressure feed to adapt from the metric thread to my Autometer sender, much easier than using that cover and drilling/tapping.
Jody
TA219
10-24-2007, 09:23 AM
What i did for the oil pressure is bought one of these adaptors http://www.performancetrucks.net/forums/showthread.php?t=392131&highlight=oil+cooler and then used an autometer elec gauge.
then buy the 1/8 male - female 90* adapter and attach the elec sender
Because the sender is pretty big it woulnt fit and look nice behind the intake so next to the oil filter was a good fit in my scenario
DCx
10-24-2007, 10:06 AM
tony did you get that oil pan side cover? i have a spare sitting right here. also i finally sold and shipped my LS6 intake and fuel injectors. i have my edelbrock victor jr in the mail. im just going to run the autometer m16x1.5 to 1/8 npt adaptor and run the autometer sending unit on the back of the block. my current SBC has a 45* fitting and it clears all the madness of the dist, wiper motor, and coil, with room to spare.
i didnt drill out the oil pan side cover.
if you need that side cover let me know. i will run to the post office and drop it in a priority envelope.
i also bought a m12x1.5 to 1/8 npt fitting for the autometer temp sender. its all coming in the mail with my intake. ill let you know how it works out.
Steve1968LS2
10-24-2007, 10:12 AM
He's not running the stock oil pan, so that gizmo won't help him. :)
trapin
10-24-2007, 12:09 PM
I think the gizmo he's talking about I need. The AutoKraft oil filter adapter has an area on that side that needs to be capped off. My adapter didn't come with one but I think Autokraft sent him one and then he ordered another by mistake...or am I mistaken? Yes, Justin...send that to me if you get a chance. I'll Paypal what you want for it.
https://static1.pt-content.com/images/pt/2007/09/oiladaptor-1.jpg
DCx
10-24-2007, 01:31 PM
its GM part number 12577903. i think its found on CTS and GTO oil pans. i think it was a special order part because it didnt show up with the gaskets i bought. so i ordered another. a few days later 2 showed up.
Tony here is the part number for the gasket to use with it 12553210. or just RTV the hell out of it. also you will need 2 m6x1.0 bolts for the side of the oil filter adaptor, and 2 for the rear of the oil pan. i had a hell of a time finding shorter bolts for the oil pan.
did you drill and tap your block for the missing oil pan hole? if not i have the drill bit and tap i can throw in the envelope. let me know.
I just dug up your address from my pay pal account. PM me and respond to the thread and ill go to the post office.
trapin
10-24-2007, 01:55 PM
PM sent. Thanks Justin.
Steve1968LS2
10-24-2007, 01:57 PM
But wait, your not using a factory style oil pan.. I could be mistaken but that part hooks to the OEM oil pan. Your autocraft pany won't have that provision.
Am I missing something here??? lol
Steve1968LS2
10-24-2007, 01:59 PM
Ok.. gotcha. Many people think that oil doohicky for the oil pressure is on the block when in fact it's on the pan.
I need a beer.
camcojb
10-24-2007, 02:05 PM
still think it's easier to use the autometer metric adaptor and put it in the rear of the intake cover like a normal small block would be. You can see mine in this pic:
camcojb
10-24-2007, 02:09 PM
and you can see the factory water temp sensor on the drivers side of the head for the EFI computer here:
https://static1.pt-content.com/images/pt/2007/10/malitude20191-1.jpg
and the Autometer adaptor and regular gauge temp sensor on the passenger side of the head, at the rear:
https://static1.pt-content.com/images/pt/2007/10/malitude20192-1.jpg
hotrdblder
10-24-2007, 04:06 PM
just had to show it off uh jody, lol
killer!!!
tony, do it how jody has it
WS6
10-24-2007, 04:26 PM
Tony,
I'd do it like Jody did cause that's how I did it :). I had an oil temp sensor as well so I drilled the cover that you just purchased for it. If you're not running oil temp, don't worry about it. I bought both the adapters for the cylinder head and the rear of the block from autometer and had no issues. Just realize that your oil sender on the back of the block is in the block itself not the intake valley cover like on Jody's car.
Jody, that's an LS2 right? Is that Malitude? Ok off topic but are you still building that mean turbo LT1 69?
Patrick
10-24-2007, 04:34 PM
Where are you getting the Autometer metric adapters and do you have the part # for H20 adapter?
Patrick
camcojb
10-24-2007, 04:43 PM
killer!!!
:smoke:
camcojb
10-24-2007, 04:44 PM
Tony,
yes, that's an LS2 going in Malitude. I sold the twin turbo LT1 Camaro to Pascual Marquez a couple years ago.
Jody
DCx
10-24-2007, 05:51 PM
here ya go.
http://www.autometer.com/cat_accessorieslist.aspx?pid=11
trapin
10-24-2007, 06:33 PM
Thanks for all your help everyone. I think it's clear now. My only concern is that I don't think the autometer oil sensor will fit on the back of the block and clear the firewall with an LS6 intake setup. I guess I'll find out when the engine and trans is in the car (which won't be too much longer). Thanks for the parts link, Justin.
DCx
10-24-2007, 07:06 PM
i know it should fit with the victor carb intake. i got my heads today and finished the engine. ill post some pics after dinner.
Payton King
10-25-2007, 07:10 AM
Mine clears just fine and I ran it like Jody showed in his photos. I am running a FAST intake. Eqqius makes a metric to NTP adapter kit for about $9.95, that is what I used for the oil and water temp.
trapin
10-25-2007, 08:37 AM
Yep, that's probably how I'm going to do it too, Payton. Thanks for the pics Jody. I am using the S&P conversion plates to mount my engine so I think their will be plenty of room back there. If I was using the ATS ones I would be concerned because I know those set the engine back a bit.
Payton King
10-25-2007, 08:55 AM
and get you a pic. Plenty of room from the firewall and my motor is close.
trapin
10-25-2007, 09:56 AM
Thanks.
WS6
10-25-2007, 05:47 PM
Tony,
Which oil pressure sender do you have? They have two depending on which gauge you have. One is big and round like a small can, typically gold. Only takes one wire to hook it up on the end of a stud. The other is a small silver one that actually looks much more reasonable to be a sender and has a three pin plug.
If you have the big one, I would plug the hole on the top of the block and mount that huge thing down low off the cover at the filter. It's too hideous not to hide as much as possible. Just my thoughts though.
DCx
10-25-2007, 09:19 PM
i got the m12x1.5 to 1/8 npt adapter in the mail today. fits the head perfect. i will take pics of the oil adapter when it shows up.
trapin
10-26-2007, 03:26 AM
Trey, I haven't bought it yet. I would want the one that Jody has though because it looks to be almost the size of the original sender. That big gold one might give me problems with my headers because I'll have to mount it horizontally as opposed to vertically if I still had my original oil cap for the filter.
WS6
10-27-2007, 02:09 PM
You'll want the electric full sweep gauge then. That is the one with the small sender that has the three plug connector. It will fit into the gold adapter and then into the block. It will clear the LS6 intake
trapin
10-27-2007, 07:17 PM
OK now you've lost me again. LOL!!!
DCx
10-28-2007, 03:13 AM
i think hes talking about this sender. it is also 1/8 npt, so you will still need the m16x1.5 to 1/8 npt adapter.
100 psi full sweep
http://www.autometer.com/cat_accessoriesdetail.aspx?vid=27
eye sore or not, im reusing my oil sending unit. the carb and air cleaner will hide it if the wiper motor doesnt.
80 psi short sweep, large canister type supplied with my electric phantom gauge.
tony did you get your package yet?
trapin
10-28-2007, 06:59 AM
Yes I did and the hole has been tapped and the pan is on. Thank you very much. I'm puttin them back in the mail to you tommorow. I appreciate you doing that. PM me your shipping costs and the cost of that cap and I'll throw that in the box too.
WS6
10-28-2007, 03:19 PM
Good job DCx. That silver sender is exactly the one I am referring to. That one will definitely fit behind the intake manifold. The large gold one on the other hand may not.
Tony, that sender is only used for the autometer gauges that are full sweep electrics.
This is a full sweep electric and it happens to be the style I am using as well.
http://www.autometer.com/cat_gaugedetail.aspx?gid=2571&sid=4
This is a normal or short sweep electric gauge
http://www.autometer.com/cat_gaugedetail.aspx?gid=3433&sid=4
DCx
10-28-2007, 05:09 PM
im stuck with the big gold one. my electric phantom 2 5/8 oil pressure is a short sweep gauge.
trapin
10-29-2007, 05:08 AM
Justin or Jody....do you guys have a part number for the temperature sensor you're running?
The full sweep 100psi is $100 from Detroit Speed Shops but the short sweep is only $29.99. I'm only going to do short sweep for my oil and
water guages. I am running the Autometer Carbon Fiber series.
DCx
10-29-2007, 12:39 PM
this is the sender that was provided with my autometer gauge
http://www.autometer.com/cat_accessoriesdetail.aspx?vid=32
this is the adapter i bought for the temp sensor. m12x1.5 to 1/8 npt
http://www.autometer.com/cat_accessoriesdetail.aspx?vid=61
the m12x1.5 adapter recommends using this shallow sender... i never noticed that is said to use it?
http://www.autometer.com/cat_accessoriesdetail.aspx?vid=33
DCx
10-30-2007, 06:05 PM
plenty of space with the victor
https://static1.pt-content.com/images/pt/2007/10/oiladapter-1.jpg
Bow Tie 67
11-10-2007, 03:20 PM
I did not read all the replies, so I apologize if I'm repeating anyone.
Tony I used the temp and oil psi senders supplied with my SW gauges. I plumbed the oil psi at the back of the block where the original oil psi switch was. ( one wire sensor for idiot light on F body cluster ) I'm running a LS 6 manifold and used the EQUUS adapter kit 6848 http://i2.ebayimg.com/07/i/000/c1/4d/443b_12.JPG and a 45* brass adapter from a local home store. The water temp was installed with adapter in the passenger aft head unused port. These were wired directly to my gauges and work perfect.
HILROD
11-10-2007, 04:02 PM
Matt, this is what you posted as an adapter kit. I guess you do like that interior. I can hook you up with a wheel like that.https://static1.pt-content.com/images/pt/2007/11/443b_12JPG-1.jpg
CarlC
11-10-2007, 05:57 PM
That is the coolest center console I have ever seen.
WS6
11-10-2007, 07:16 PM
The whole car is for sale if you like it that much carl.
