View Full Version : do your DSE/Koni shocks make noise?
CamaroAJ
10-18-2007, 06:10 PM
rear mini tub shocks, i cannot get it to make the rattle noise no matter what i do sitting still. i can however make it do it on the road over most bumps. its driving me crazy, i checked for anything loose or contacting the body in the trunk and under the car and found nothing. i am wondering if it is the right rear shock since it has the hime (sp?) joint stule ends on it. i need to being my chassis ears home from work and see what i can find, also switch shocks from side to side and see if it changes. just kinda wondering if anyone has had a problem with there DSE/Koni shocks.:banghead:
the camtender
10-18-2007, 06:44 PM
Two yrs.heavy abuse,no problems
Jerry
awr68
10-19-2007, 02:43 PM
Are they bearing or poly mount? If bearing mount then yes, you should hear them a bit.
CamaroAJ
10-19-2007, 02:56 PM
bearing.....but its only from one side of the car.
TD509EFI
10-19-2007, 07:59 PM
Years ago I had a brand new rear Koni shock straight out of the box that knocked over some bumps when installed on my car. Couldn't find anything loose. Returned the shock to be checked. Koni sent a replacement. No more noise!
John
Chevy
10-22-2007, 08:04 PM
Can't hear shocks over the sound of my screaming small block...
Sorry, can't help...
:firefire:
