View Full Version : Rag joint question
s10cyncrvr
10-14-2007, 06:18 AM
I just installed a 800 series box from Lee's. I'm thinking about replacing the factory rag joint with a high perfromance one from them. Do you get the enitire rag joint assembly? or do you cut apart your stock rag joint and replace the disc? Anything else I should know about the swap? This is in an 02 S-10 by the way.
6'9"Witha69
10-15-2007, 09:20 AM
The only wear part is the disc. It can easily be replaced.
UNISTEER
10-18-2007, 12:40 PM
Jeremy,
The splines on the input shaft of the box you bought are different than that on your stock gear box so a new rag-joint is needed.
We offer this style box alone or with the necessary rag-joint (coupler) and adapter fittings that enable you to use your existing steering hoses for older cars.
https://static1.pt-content.com/images/pt/2007/09/8040050-1.gif
The GM 600 Box is slightly lighter than other power steering boxes and is available in several different ratios for optimal steering performance depending on the vehicle; 12:1, 14:1, and 16:1 ratios are available for this steering box.
Unfortunately, WE DO NOT sell the rag-joint seperately.
6'9"Witha69
10-18-2007, 01:12 PM
ATS does.
http://store.nexternal.com/shared/StoreFront/default.asp?CS=ats&StoreType=BtoC&Count1=287212550&Count2=204352974
Look under the suspension category.
s10cyncrvr
10-19-2007, 05:46 AM
Jeremy,
I'm running the 800 box, so I don't need the conversion rag joint, just a stock replacement. Judging by that conversion one, it looks like they give you the enitre assembly.
