View Full Version : What kind of pistons are these?
Project69
10-11-2007, 12:32 AM
There lableled L2165 030. I know that there for a 327 motor and its .030 over with 4-valve flat top, but who makes it and are they forged or hyper or cast?
Also can 327 pistons be used on a 350 block since there bore is the same?
Jims78elky
10-11-2007, 01:50 AM
Iam not totally sure,so Iam taking a stab here,but from what I came up with is there 1962-69, 8 cyl, 327 cid, standard engine, std, .030, .040 pistons and I believe there TRW brand.Though I think there a cast piston..Iam not really sure though.
Here is the reference that I found.
http://www.vapinc.com/chevy/Pistons/main.html
Hope it helps some!
-Jim
Project69
10-11-2007, 05:33 AM
camcojb
10-11-2007, 06:41 AM
327 won't work in a 350 due to pin height difference. It does sound like a TRW piston and all forged ones I've seen had an F after the number (L2165F) so with no "F" I'd say it's a stock cast 327 replacement.
Jody
Project69
10-11-2007, 07:06 AM
Thanks, I have a large main journal 327 block, can i use a 350 crank, rods and pistons in it or will the crank not clear the block?
Adam's 55 Chevy
10-11-2007, 07:54 PM
You will have to see but relieving it will be risky.
pdq67
10-13-2007, 12:34 PM
I gotta say that a 327 piston can be used in a 350 block IF the 327 engine's rotating assembly is used!!
You can't use a 327 piston w/ a 350 crank!!! Sucker will stick outta the top of the block about an 1/8"!!!
pdq67
Project69
10-13-2007, 12:56 PM
What about a 350 piston with a 327 crank? I have a 327 large main journal and rod crank and want to use 350 size pistons. Can i do that?
The block is a large main journal 327 out of my 69'
camcojb
10-13-2007, 01:00 PM
then the piston will be way down in the hole. You have to match the rotating assembly (crank) with the pistons. You can build a 327 or a 350, but cannot mix and match between the two. I guess you could use a 350 piston on the 327 crank, but you'll have a major compression drop, lousy quench, etc.
Jody
