View Full Version : Question on Energy suspension mounts for a 68 GTO
josht
10-10-2007, 07:24 PM
The 68 GTO is a GM A-body. So are all the frames the same or are the body/frame mounting points for the body bushings different?
I did send Energy Suspension a email and was told that the part number below has not been tested at this time.
I have the ones sold by OPGI and they are vey soft, I think they are going to flex too much. I was following the delrin thread but it looks like they may not get produced...
Energy Suspension has Part Number: 3.4115 Body Mount Bushings - Non Convertible list for a 68 - 72 Chevelle.Would these work on a 68 GTO?
10-10-2007, 07:34 PM
It depends on your lower control arms, one of the lower bushings is oval shaped.
I had the same issue when I was building mine and I ended up running a set of 69 Chevelle lower arms with the round bushings cause my stock arms where bent anyways.
josht
10-12-2007, 08:21 PM
?? I am refering to the 12 body mounts. I don't think lower control arms would come into play here. I am using GW LCA with Delrin bushings.
TIA
10-12-2007, 09:30 PM
oh, ok sorry i failed to read your post completely.....I used the set I bought for my 70 Chevelle. I just matched up the ones that came close and used my old hardware.
