View Full Version : To seal or not to seal?
danbob67
10-10-2007, 07:59 AM
allright for all you "show" car painters in here or people who saw there show car painted. do you seal em all or not? are you just wet sanding the primer then going to base coating. Or just seal on certain colors like silver. how does your paint process usually go?
Smock67
10-10-2007, 11:50 AM
Well I sealed mine. Just haven't painted it yet. I would recommend it personally.
Happyfunballs
10-11-2007, 04:38 AM
I would say it depends on the transparency of the color. If you have a color that covers well, then I wouldn't, it's just another coat of paint that can attract dust. JMHO. I don't seal much anymore.
danbob67
10-11-2007, 08:15 AM
I dont seal to much either, Ive been in the same shop painting for the last 10 years and I dont get to see to much from other people painting I was just curious what kinda replies I would get. I hadnt planned on sealing mine just one more coat to add texture and nibs even though I was gonna reclear anyway.
Gordz32
10-15-2007, 07:42 PM
We seal everything here at Best of Show. From bare metal we epoxy prime with PPG DP primer, then we use a high build poly primer, block the car, seal it with ppg DP again and then apply base and clear.
z4me69
10-15-2007, 08:17 PM
gordz i am doing my 69 the same way when using the dp as a sealer do you mix it the same as you would over bare metal ?
Gordz32
10-15-2007, 08:31 PM
No When useing a a bare metal primer use dp401lf and allow 1 hr at 70 degrees induction time before spraying. When useing as a sealer use dp402lf and you can spray at ur leisure
Over bare metal it mixed 2:1 with DP401LF
Used as a Sealer its mixed 2:1:1/2 with DP402LF and DT reducer
Somebody correct me if I'm wrong
