Edmundo
01-10-2005, 07:04 PM
I have a 2004 Pontiac GTO. I would like to improve upon the factory suspension and turn my car into a real sports sedan with easy, controllable and sure-footed cornering capabilities. I know many of you are more into chasis mods, however I would like to work with the original setup and use available, american aftermarket products. Intended use is street.
The info about the OEM package I have been able to gather is the following: 1. Wheels 8J x 17". 2. Tires: 245/45 ZR-17. 3. Spring rate: F: 175 lbs R: 320-400 progressive. 4. Sway bars: F: 1 1/8 R: 5/8. 5. Total weight 3,725 lbs. 6. Weight distribution: F: 55% R: 45%. 7. Shock absorbers: Monroe.
I would like to lower it as much as technically convenient. I have seen at least 2 coilover kits and 3 lowering spring sets. Edelbrock, qA1 and Hotchkis have nothing for this car yet. Will be looking into some alignment numbers after lowering.
Thank you very much for your help and advice.
