View Full Version : Front suspension issues
73-TYPE-LT-LS1
10-02-2007, 10:23 PM
I know this isn't car related but I could use some help and I know there are some smart guys here..
Since I bought the 63 truck I have wanted to do something about the suspension. Not sure who lowered it before I bought it but they used the "good old" torch method. The springs looked like pretzels.
I ended up buying spindles and a 1" spring for the front and 2" springs and 2" blocks for the rear. I was waiting for the blocks to come in (back ordered) so I put the rear springs in. I only sit's 1/2" higher than it was. I thought it was going to be a bit higher. I have yet to add the blocks.
I started in on the front end today. After having to heat the spindles and ball joints the spindles broke free. As I was putting the new spindles on I realized the ball joints are too long. The cotter pin hole is about 1/4" above the top of the nut when bolted down. :hmm: The next thing I notice was the diameter of the tierod end is bigger than the hole in the spindle. :pat:
I vaigly remember the guy that sold me the truck say something about using parts off a Camaro when doing the 5 lug conversion. Everything is 5x5 bolt patern. The bearings fit the spindle just fine and the caliper lines up with the disk. I'm assuming if the spindles are Camaro's they are from a 70-81 as they are front steer.
Anyone know if the geometry from a Camaro spindle would be the same excluding the balljoint and tierod issues I am having?
I'm thinking I need to order new balljoints and tierod ends.
