View Full Version : t56 swap help needed.
lethal95
01-08-2005, 08:30 PM
im trying to mate a 1997 gm t56 to my 406 cube small bock chevy. heres the problem. i cant seem to find a flywheel for a 400 sbc external balance motor for this swap. its a 168 tooth flywheel. i know ill have to clearance the bellhousing for flywheel clearance with the 168 tooth. my question is. what flywheel do i use to get the lt1 pull style clutch to work with this and is it possible in any way to use a 153 tooth? thanks in advance
Joe-
TitoJones
01-12-2005, 04:54 AM
You HAVE to use a 153 tooth in a LT1 setup. The bellhousing will not clear a 168 tooth version.
McLeod part numbers:
2pc rear seal, 400, zero balance-460370
2pc rear seal, 400, counter balance-460370-2c
Tyler
zuess4u
01-12-2005, 02:03 PM
Tyler correct me if Im wrong, but he could also use a stock 153 flywheel external balance, if Im miss informed, explain, cause I would like to know the difference, besides the price and weight.
camcojb
01-12-2005, 05:14 PM
I believe the flywheel for the pull-off LT1 clutch is different than the standard flywheel for a regular clutch. You need to buy the complete assembly of flywheel, pressure plate, and disc with the throwout bearing.
Jody
andrewb70
01-13-2005, 11:13 AM
What Jody said.
lethal95
01-13-2005, 11:43 PM
thanks for the help everyone. i ordered the flywheel sunday and it came in today. it sets on the motor now. im about to order the spec stage 4 kevlar clutch also. btw i ended up getting the centerforce 700173 flywheel. with counterbalance. ill let everyone know how the setup progress's. cant wait to drive this thing
lethal95
01-13-2005, 11:52 PM
oh yea one more question. whats the torque on flywheel bolts and the torque on pressure plat bolts? thanks.
