View Full Version : Keisler hydraulic clutch kit
streetk14
01-08-2005, 04:51 PM
Just wondering if anyone out there is running a TKO with the hydraulic clutch set-up from Keisler auto. I will be switching to a hydraulic clutch when I install my new Wayne Due subframe in a couple months. I spoke to someone at Keisler, and it is supposed to be a bolt in kit that uses the stock clutch pedal. I'd like some feedback on the install and performance if anyone has any. Thanks,
Andy
EFI69Cam
01-13-2005, 07:56 PM
Andy
Keisler makes decent stuff, but they are not the quickest at filling orders, order your stuff well in advance.
tuff68
01-14-2005, 10:03 PM
I have a viper T-56 that I bought from Keisler. They built it with an LT1 input shaft. I have the hydraulic concentric slave that bolts to the front of the tranny. I am also using a Weir bellhousing, clutch master and crossmember. I can use a stock style 11 inch clutch setup. I started this project before Keisler had the bolt in kit. Dont know how it works yet because I just got my Camaro out of the body shop and I am in the slow process putting it all back together. When I get it going I can let you know how it works.
Mike
