65protourgto
09-25-2007, 11:27 PM
Hey, there I just thought I would ask what you guys all think of my new part Im going to be machining for my GTO. Alright I am using a non stock chassis so this is part of the reason Im making these bushings. The bushings start out with nylatron(nylon MD) cut to the same size and mimicing the stock A body bushings. I figure if any one wants them for there car I could either make them up for you or show you picures soon showing what is needed to make them. I figure this is a great alternative to solid aluminum bushings, the nylon im using is hard but has great wear properties and has more cush then aluminum. I figure by using these bushings, it will tie the body together better then a stock mushy rubber bushing. These bushings will still retain some cush needed and last longer then the stock bushings.
