View Full Version : Question about my starter.
CamaroJesse
09-24-2007, 12:15 PM
i have a 396 BB with an lt1 6 speed and a 153 tooth flywheel. I bought an LT1 starter like TAS told me to and it does not fit the bolt pattern on the big block. So, i was wondering if the starter i took off the bigblock would work. its a high torque mini starter but it was used on a 168 tooth flywheel before. Could this starter possibly work for me?
thanks
09-24-2007, 07:46 PM
You are going to have to get a starter made for a 153 tooth flywheel. Most mini starters go both ways.
CamaroJesse
09-25-2007, 04:22 AM
Well mine is a mini starter. Should i just try it?
HILROD
09-25-2007, 12:17 PM
Some mini starters have dual mounting bolt patterns, 4 seperate holes in the mounts. If yours has this it will work. If not I've seen people drill the block for the other starter style.
6'9"Witha69
09-25-2007, 01:03 PM
That or the starter can be clocked in the housing to make it work in a variety of applications including 153 v. 168 tooth flywheels.
