View Full Version : what power steering pump can i use
jeff5347
09-20-2007, 09:13 PM
Hey guys, im looking to retire the old saginaw PS pump that i have (came off a 78 malibu) and install a late model pump with a remote resevoir. I dissasembled the pump tonight and pulled it out of the saginaw body. My setup right now is the factory 68 camaro steering box but over the winter ill be doing the 3rd gen conversion. I just need to make sure the pump i use wont cause any problems. Am i able to use this pump and run a remote resevoir instead of buying a new pump?
If so, how would i do this?
If not would one of these work, Could i take of the factory clip on resevoir and have a remote resevoir?? Im on a tight budget so making something work by fabbing is not a problem. All help is definately appreciated.
http://cgi.ebay.com/ebaymotors/GM-POWER-STEERING-PUMP-KIT-88964571_W0QQcmdZViewItemQQcategoryZ33588QQihZ014Q QitemZ330140717758QQrdZ1QQsspagenameZWDVW
could i use this one and use a remote resevoir instead?
http://cgi.ebay.com/ebaymotors/GM-3-1-liter-power-steering-pump_W0QQcmdZViewItemQQcategoryZ33588QQihZ005QQite mZ150089427672QQrdZ1QQsspagenameZWDVW
http://cgi.ebay.com/ebaymotors/NOS-POWER-STEERING-PUMP-RENAULT-SAAB-GM-DODGE-EAGLE_W0QQcmdZViewItemQQcategoryZ33588QQihZ019QQit emZ290159026309QQrdZ1QQsspagenameZWDVW
http://cgi.ebay.com/ebaymotors/GM-Power-Steering-Pump-Kit-26043370-NEW_W0QQcmdZViewItemQQcategoryZ33588QQihZ001QQitem Z110168960241QQrdZ1QQsspagenameZWDVW
I know i threw a lot on here. If these arent good canddiates what do you recommend.
Thanks Jeff
09-21-2007, 09:10 AM
I used the Speedway Motors pump here:
http://www.speedwaymotors.com/p/2067,177_Power-Steering-Pump-With-Pulley.html?itemNo=steering%20pump
We got the pump and reservoir kit, the pump and mount was fine for long water pump cars with V belts. The reservoir is not good, aereates the flow. I modified the return fitting to fix it.
If you buy a rebuilt pump, make sure it comes with the pressure valve in the outlet port. The older pumps required you to swap over the valve from your old pump which you don't have.
David
