    Results 1 to 20 of 33
      St. Pete FL
      04-06 GTO seats in 2nd gen F-Body (70-81)
      Has anyone done it? Will the fronts fit? Rears? What mods?
      I found 1 pic from a 70 IIRC camaro but no info. I'm putting them into a 71 TA. Thanks ;)
      Dublin, CA
      Don't qoute me, but I seem to remember reading awhile back that the GTO seat are too tall (both overall and seat height). Might want to do some measuring. They are a good looking seat though.
      Brent
      Aug 2005
      Hamilton, NJ
      IIRC there might be a width issue. I may have the wrong OE seat on my mind.
      Scott from NJ.
      Vent Windows Forever! ...
      Hackettstown, NJ
      gto seats are too wide. a vette or obiously f body seats works fine.
      St. Pete FL
      :( :( :( :( :( :( :( Crapola!!! :( :( :( :( :( :( :(
      Jan 2007
      Have you found anymore information on the car in your picture? I bought a set of 06 gto seats to put in my 78 trans am. They are definitely too tall to just bolt in. I was going to see if I could lower the floor pan and flatten it out to make them work. They're probably the most comfortable sports car seats that gm made.
      St. Pete FL
      No but we are in this one together! I'm about to go pick up a set as well for my 71 TA! I think they look great & agree they are probably the most comfortable seats that GM has made. How much modding are we looking at? I was hoping it wouldn't be that bad but looks like I will need to break out some flat stock, C.O. wheels, & welder for this one :( How bad are the back seats going to be? What did the set cost ya?
      Jan 2007
      I paid $815 w/ shipping for a set out of an 06. The problem with the gto seats is that the floor on the goat sits very low and is wide. I came up with 3 ideas for mounting the seats.
      1. Cut out the floor and make the floor board wider and deeper. I would make it all the same level. I am waiting to get my exhaust system figured out before I can do anymore with this idea.
      2. See if an upholstery shop can take some of the height out of the lower portion of the seat cushion.
      3. See if I can adapt the seats to use a narrower seat frame. The 94-96 caprice and impala use a narrower power seat frame. I am also going to look at the seat frame from my bonneville seats.
      Each option will require a decent amount of work. I was hoping to find someone else that has done the install to see what kind of issues they ran into. I really like these seats and want to make them work. With the high replacement cost, I don't want to make any mistakes installing them.
      The back seat should be easier to install. I was going to have the bottom portion modified to fit over the hump in the middle and make some brackets for the upper portion.
      Texas
      How tall are they w/o the headrests? -Bob
      St. Pete FL
      hmmm, it does look like this is going to be more of a job than I thought...
      When are you going to start cutting / modifying? I haven't even got mine yet. Went to pick them up & fould out one of the backs was ripped. Offered me $50 off & I told him what to do with that $50 for having me drive down there, Err!!!
      Keep me informed & I will do the same for you. We should be able to do it! THANKS :-)
      Dec 2007
      Gilroy, CA
      I am in the same boat. anyone have any updates? they seem a little tall but i could get rid of the power options if i have to...These were too good of a deal to pass...550 out the door.
      1969 Chevelle
      www.creationsultd.com
      OC CA
      Quote Originally Posted by cdoggy81
      Chris and & 76LQ9,
      I don't have a clue about the GTO seats in particular, but I will add my .02:
      2nd gen headroom is real tight to begin with, so whichever seats you use, they need to be as low to the floor as you can get them.
      When I installed my Arizens, I used the co. they recommend on their website http://www.wedgeengineering.net/, and I can say that they worked perfectly. They have measurements for your cars, and can build a set for about $160.00 + shiipping. Good guys there.
      Mark
      Mark
      LS1- T56
      under construction
      "Political Correctness is a doctrine, fostered by a delusional, illogical minority and rabidly promoted by an unscrupulous mainstream media, which holds forth the proposition that it is entirely possible to pick up a turd by the clean end."
      Ontario, Canada
      Add me to the list. 04 GTO seats in a 71 Firebird.
      Has anyone tried ditching the power seat rails for lower rack?
      Dec 2007
      Gilroy, CA
      Yeah Im going to look into taking off the power seat rails and see how it fits... does anyone know if these seats have a heater in them? If so what color wire controls the heater?
      1969 Chevelle
      St. Pete FL
      I just bought a complete 04 GTO & my 1970 TA roller just arrived so I'm ready to go now!!! I'm very excited that I'm not the only one in this boat now It will be a bit before the sparks fly but I will keep everyone informed if I figure anything out. Same for you guys. Looks like we will be able to make it work! Mike, thanks for the link & talking with me the other day.
      HELP!!!
      Dec 2007
      Gilroy, CA
      How much did you pay for your set?
      1969 Chevelle
      Dec 2007
      Gilroy, CA
      Bump to see if we get any bigger of an audience...
      1969 Chevelle
      Dec 2007
      Gilroy, CA
      well just an update but my dad ( CNC machinist for 20+ years ) began working on this project. We decided to make some brackets to use the stock mounting holes instead of drilling new ones in my perfect floor boards. If the crowd is big enough we might produce them cheaply for all you car guys. Stay tuned... I'll have updates soon.
      1969 Chevelle
      Ontario, Canada
      Quote Originally Posted by dstryr
      Your mounts seem to solve the height problem; however what about the width? Or is that an issue? My car is not around for me to go out and test fit the seats.
      That being said, if these mounts work I am in.
      St. Pete FL
      Me 2!!!
      HELP!!!
