View Full Version : Photo Shop Help!!
Lil Bob
09-19-2007, 03:02 PM
19209
19210
Hey i was woundering if someone could drop my car for me? Also do you think that it needs to be dropped? I can't decide if i want to or not.
gionni
09-20-2007, 07:13 AM
voilą!
yes, is necessary to drop it... :twothumbs
Lil Bob
09-20-2007, 08:19 AM
Hey thanks a lot for the drop. I will look into what it is going to cost to drop the chevelle. Thanks again.
Bobby
TonyL
09-20-2007, 08:23 AM
that drop looks to be about one coil's worth. Cutting one coil would not "hurt" the suspension much. Just firm up the spring rate.
Lil Bob
09-20-2007, 01:39 PM
I heard that if you cut the springs then the car may not sit level. it that true?
TonyL
09-20-2007, 01:44 PM
It all depends on how careful you are at where you cut them and weather you put them back in and they "seat" correctly.
Lil Bob
09-20-2007, 01:48 PM
Thanks for the input is there anything else that should be done i don't know what to do i have run out of ideas.
TonyL
09-20-2007, 01:59 PM
Dont use a torch. the heat ruins the springs. Use a cutoff wheel or saw.
Grind the edges of the cut and put a bevel around the edge to prevent any squeekyness. Take the car to an alignment shop immediately after.
It's a good time to look at ball joints and junk while you're at it.
Nice car BTW.
TonyL
09-20-2007, 02:01 PM
judging by the pics you may need to check the fender to tire clearance and may have to roll the lip a little. (do a search on fender rolling here.)
You may also consider upgrading to a higher quality shock.
Lil Bob
09-20-2007, 02:12 PM
Thanks, but what is fender rolling i have never heard of it and i am about to search it on here so maybe ill find out.
TonyL
09-20-2007, 04:05 PM
fender lip rolling is a way to gain tire clearance. It involves bending the lip up under the inner fender well. There are tools made for this, or you can do it with pliers. good luck.
Lil Bob
09-20-2007, 06:29 PM
Can Some one put Bigger wheels on my car in the original and the dropped version? Please.
