UNISTEER
09-19-2007, 07:43 AM
You can dramitically upgrade & improve the steering & handling of your 1964-72 GM A-Bodies with one of our new rack & pinion kits.
Our rack kit easily bolts on & includes the rack & mounting bracket. The kits are designed to be used in conjunction with our various power steering pump kits with either remote resevoirs or a clip-on resevoir for short or long water pump Big Blocks or Small Blocks.
You can also select one of our steering shaft kits to suit your needs whether you have a stock or aftermarket steering column.
Our Chevelle kits feature a black powdercoated heavy duty bracket which eliminates any twisting or flexing present in the competitor's kits; take a look.
https://static1.pt-content.com/images/pt/2007/09/801070001-1.jpg
You won't have to worry about ground clearance with our kit either.
https://static1.pt-content.com/images/pt/2007/09/Chevellepics016-1.jpg
We are currently offering a 10% discount & FREE SHIPPPING (to lower 48 states only) for a period of 60 days on anything we sell.
So if you are interested in improving the steering of your ride take a look at our website and use the discount code: PT-10
