View Full Version : t56 install questions
barraza
01-07-2005, 10:12 AM
I have an aftermarket t56 going into a 67 camaro. The aftermarket version comes with a reverse lockout soleniod, do all t56s have it? What is a good way to hook it up? I really didn't want a switch on the shifter handle. Can it be replaced with some sort of spring loaded alternative?
TitoJones
01-07-2005, 11:05 AM
It can be overridden under 5 mph, and yes, all T56's have one. I usually put a 12v switch on the brake pedal to activate it.
Tyler
barraza
01-07-2005, 11:52 AM
tyler
What do you mean it can be overridden? What is it hooked up to in a factory application? Reason I asked is that I read somewhere that it is removed in some apps for clearance, but I can't find the article and cant remember what they replaced it with.
I'll get back to you on the crossmember. I already have a turbo 400 crossmember I may try to fab one out of it if I can find it.
