DeltaT
09-18-2007, 01:01 PM
Hi All,
Great site - I've gotten a lot of excellent info here.
As an insurance policy for hot days, track days and the occasional dyno run, I'm adding an alky system to my Vortech-blown (T-trim), intercooled 383 with the Holley 950 Commander Pro (with FJO Racing Wideband controller). I chose the FJO Racing Alky/Water Injection controller, pump and solenoid nozzle. I also got the cable that interfaces the alky to the wideband controller.
I do plan to run a 33% distilled water/67% alky mix, to keep the boiling point of the alky a little higher than straight alky so I don't have to worry about it disappearing from underhood temps.
My question is how to change my current 950 tune to accomodate the alky. Since I can pick the RPM, TPS and MAP points where the alky will start, and how much to inject, I'll be starting at the 6# of boost level. The alky will inject right at the 'hat' sitting on the 4bbl throttle body, and my injection is multipoint. The alky will inject pointing directly upstream at the incoming air.
I figure maybe I should just use my current setup as is, run a small amount of alky and datalog a couple runs, then trim fuel out until I get AFR's in the 11:1 range at WOT and above 6#. I max out at close to 11# with this setup.
Any feedback on this approach?
Also, once I get the fuel part of the tune stabilized, I was planning on going back and adding back in some timing. Anyone have experience on how much timing to use with alky at 11# of boost? My non-alky current tune is set to a conservative 17 degrees advance at 11# boost, and around 24 degrees at 6#.
All suggestions and ideas welcome.
Jim
My Site: http://home.mindspring.com/~jim_fisk/id1.html
Jim
