CamaroAJ
09-07-2007, 12:06 PM
on my car with i did the whole 2002 camaro dash and column, i also used the entire body harness so everything works like it did on the 2002 camaro. if you are going to do that and you need a way to make your tail lamps work right with the turn signals this is the wireing you will need to use. took me about an hour to figure out a way to make it work and then build a model of it but it worked well. hope this helps someone out one day.
https://static1.pt-content.com/images/pt/2007/09/brake_turn_lamps-1.jpg
