View Full Version : VFN or Unlimited
scogin918
09-07-2007, 07:56 AM
These are the only two companies that make the hood I want. It's the L-88 style hood that came on the big block corvettes in '69 but made to fit the Camaro. Both offer a bolt on, but I'm using the aluminum hood pins up frot with the Detroit Speed hinges for fiberglass hoods in the back. Which one will require less work by the body man?
MarkM66
09-07-2007, 09:36 AM
I would think VFN then unlimited.
Project69
09-07-2007, 09:43 AM
+1 for VFN also. Ive seen a whole bunch of there Sunoco Hoods and WS9 hoods for the 4th gen camaros and t/a and the fit is honestly near perfect. Everything aligns properly with minimun adjustment.
scogin918
09-07-2007, 10:15 AM
Thanks guys. I know some of their strictly Drag Race stuff is pretty good, I just didn't know how some of their more refined parts were. I'll give VFN a call.
quadfather
09-07-2007, 03:41 PM
definetly vfn. do not get one from unlimited . there junk.
SDMAN
09-07-2007, 07:37 PM
Hard to beat VFN for a quality fiberglass part. Ive used several of their pieces, and all were top notch.
scogin918
09-08-2007, 06:08 AM
L-88 Bolt on hood from VFN is on the way. Well in about 4-6 weeks anyway. Thanks for the help.
SDMAN
09-08-2007, 03:53 PM
Here is the latest piece I got from VFN. Very well made. The factory chin spoiler lines up really well. Here we are doing a ride height mock up with the front tires placed at the correct track width to check fitment. Its going to work out really well.
Project69
09-09-2007, 12:08 PM
I thought about going with there 1-piece front end for my car to save weight. Looks great.
rocketman
09-09-2007, 04:28 PM
VFN or Glasstek, Unlimited is ok at best in the quality department
sunkistcamaro
09-09-2007, 07:01 PM
I have a VFN hood, looked great. Not to much work to make perfect. Dont forget to put your hood pins in... I did :eek:
MonzaRacer
09-13-2007, 06:17 PM
I do like Glastek and VFN is ok but as for me I have used and sold Unlimited Products and had nearly zero problems.
We had 2 hoods come in looking wierd and the problem was they had some hardner issues(supplier changed bulk supplier and it wasnt as strong, IE it needed to be mixed stronger) but they shipped new hoods free of charge and told us to keep the others, I cut the scoops out and bonded them to other hoods, NAd I still have my long cowl scoop that was the ONLY one long enough to fit a 70 Monte hood well.
StRacerDuke
09-22-2007, 07:10 AM
Stay away from Unlimited, they are garbage. I spent 30+ hrs on an Unlimited hood (2" for a 64 Chevelle) to get it to fit right. PITA, had to shave the sides, smooth the top, and modify the base where the hinges sit for it to be flush. VFN or Glasstek if at all possible.
Anything you get will require some work to get it to be perfect before paint. Don't be surprised if your body guy says it will take a few hours of prep!
