View Full Version : some more progress
CamaroAJ
09-05-2007, 06:32 PM
hard to not rush things now since i'm so close. it won't look good this year but it will be shaken down for any problems and what not and then torn apart in the winter for body, paint and interrior.
https://static1.pt-content.com/images/pt/2007/09/th_camaro1210051-1.jpg (http://i25.photobucket.com/albums/c80/CamaroAJ/camaro1210051.jpg)
https://static1.pt-content.com/images/pt/2007/09/th_camaro1210041-1.jpg (http://i25.photobucket.com/albums/c80/CamaroAJ/camaro1210041.jpg)
https://static1.pt-content.com/images/pt/2007/09/th_camaro1210021-1.jpg (http://i25.photobucket.com/albums/c80/CamaroAJ/camaro1210021.jpg)
https://static1.pt-content.com/images/pt/2007/09/th_camaro12022-1.jpg (http://i25.photobucket.com/albums/c80/CamaroAJ/camaro12022.jpg)
https://static1.pt-content.com/images/pt/2007/09/th_camaro12012-1.jpg (http://i25.photobucket.com/albums/c80/CamaroAJ/camaro12012.jpg)
https://static1.pt-content.com/images/pt/2007/09/th_camaro12014-1.jpg (http://i25.photobucket.com/albums/c80/CamaroAJ/camaro12014.jpg)
https://static1.pt-content.com/images/pt/2007/09/th_camaro1211008-1.jpg (http://i25.photobucket.com/albums/c80/CamaroAJ/camaro1211008.jpg)
https://static1.pt-content.com/images/pt/2007/09/th_camaro1211007-1.jpg (http://i25.photobucket.com/albums/c80/CamaroAJ/camaro1211007.jpg)
https://static1.pt-content.com/images/pt/2007/09/th_camaro1211006-1.jpg (http://i25.photobucket.com/albums/c80/CamaroAJ/camaro1211006.jpg)
jonnyc
09-05-2007, 07:17 PM
looking good.what motor mount and headers are you using?do your leaf spring perches just clamp on or are you going to weld them later?
CamaroAJ
09-05-2007, 07:48 PM
hooker headers with there mounts. right now just clamped, they will be welded after the drive shaft is in and i set pinion angle.
CamaroAJ
09-05-2007, 07:58 PM
oh and if you can't tell i made my own LED brake lamps with 2 LED trailer brake/marker lamps and 8 LED turn signal things out of chevy trucks. per side. i used GM assembly adhesive because it won't stick to the plastic part can take out the LED if anything even happens to the plastic.
part of the set-up
https://static1.pt-content.com/images/pt/2007/09/th_camaro12018-1.jpg (http://i25.photobucket.com/albums/c80/CamaroAJ/camaro12018.jpg)
the last part installed.
https://static1.pt-content.com/images/pt/2007/09/th_camaro12027-1.jpg (http://i25.photobucket.com/albums/c80/CamaroAJ/camaro12027.jpg)
this is brake lamps on turn signal part only, i'll try and get park lamp and the other part of the brake lamps tomorrow.
https://static1.pt-content.com/images/pt/2007/09/th_camaro12021-1.jpg (http://i25.photobucket.com/albums/c80/CamaroAJ/camaro12021.jpg)
CamaroAJ
09-06-2007, 06:00 PM
two from today
https://static1.pt-content.com/images/pt/2007/09/th_camaro5004-1.jpg (http://i25.photobucket.com/albums/c80/CamaroAJ/camaro5004.jpg)
https://static1.pt-content.com/images/pt/2007/09/th_camaro5001-1.jpg (http://i25.photobucket.com/albums/c80/CamaroAJ/camaro5001.jpg)
70TWO NOVA
09-06-2007, 06:58 PM
Your home made LED tailights are sick!!
CamaroAJ
09-06-2007, 08:37 PM
thanks, 4 years worth of saving warranty mirriors paid off, and they are crazy bright in person.
Rybar
09-07-2007, 09:17 AM
Your whole project looks really good, keep us posted. Looks like it's coming along very nicely.
jon72vega
09-07-2007, 05:12 PM
CamaroAJ,
Nice job on the tail lights!
I sent you a PM regarding the arrow LED's.
