jeff5347
09-01-2007, 10:12 AM
Well im pulling the engine this month and had some questions on the firewall and painting the compartment and such.
1. I wont be smoothing by laying a flat piece of sheetmetal down .
I was curious if i sanded and cleaned the firewall if anyone had put filler in the nouks and crannies to get a smoother look? If so what did you use to fill.
2. I am going to paint the firewall and wheel wells, rad support and everything under the hood. Can i use a can of good spray paint or should it be from a shop type of spray gun paint. If i can use spray paint what brand and such do you guys recommend?
3. Also going to clean the frame. What should i use to paint the frame?
Does anyone have pics of there engine bay cleaned but not smoothed by a piece of sheetmetal. This is my first undertaking of the engine compartment and i want it done right and so it will draw attention.
4. One other question. The acces. like the brake booster, wiper motor and such. What did you paint these parts with? is can spraypaint ok or a big no no.
Thanks guys for all your help.
Jeff
Jeff
