View Full Version : Front Right tire rubs on Second Gen
AButler
08-29-2007, 03:29 PM
Anyone, my front passangers tire rubs on the back of the inner fender well. What causes this? is it just the bushings or could the subframe be damaged???? any help or tricks.
GetMore
08-29-2007, 04:06 PM
The subframe may just need to be lined back up. You would probably want to replace the bushings first.
The tolerances were rather large on the cars from the factory, so there was plenty of variance.
08-29-2007, 06:52 PM
Our second gen does that too! :)
It's at full lock, the left side is very close, the right rubs just a bit.
David
Lowend
08-30-2007, 04:55 AM
Yep - back of the front fenderwells near the bottom... welcome to 2nd gen land
ks71z28
08-30-2007, 10:59 AM
Oh yeah, the more Castor you run or the lower the car is the more the wheel moves back in the opening. I wish that the tubular arm companies would move the Lower ball joint foward instead of the upper back. This is a major issue and why a 255 tire pushes the limit on a 2nd gen. My avitar is case in point, allbeit my car is quite low.
Keith
72Z/28
08-30-2007, 12:07 PM
You know what, I am having the same problem. The passenger's side tire is closer to the back of the fenderwell near the bottom than the driver's side. Such phenomenon caused the tire to rub against the back of the fenderwell when the front of the car was sitting very high. I cut the front springs half a coil, and that stopped the rubbing. yet, still the passenger's side tire is closer to the back of the fenderwell than the driver's side. I have decided to live with it :dunno:
AButler
08-30-2007, 08:17 PM
This makes me feel better at least im not the only one...... Thanks for the replies
