View Full Version : Low Fuel Level Light
touronhold72
08-27-2007, 07:19 PM
I want to run a small light or LED next to the auto meter fuel level gauge in my dash. GM sending unit is something like 90 ohms full and 0 empty, so I need to figure out how many ohms 3 gallons is approximately.
I want the light to act as a newer model low fuel level warning light that kicks on when there are just a few gallons left so you can get you ass to a gas station instead of pushing the car.
Its an electric guage so I guess I would need to find a resistor or diode that would let me split off of the wire doing to the dash and go into the light/LED.
Any suggestions?
BRIAN
08-27-2007, 08:59 PM
You can empty the tank, add 3 gallons then measure the resistance value.
For the light you can run a variable resistance switch at either end to provide ground to the LED power circuit. Radio shack should be able to help.
A diode is just a 1 way circuit so im not sure how that could work. Maybe a zener diode. That would pass current when the voltage gets to a certain level.
Larry Callahan
08-27-2007, 09:27 PM
Cool idea!
GetMore
08-28-2007, 11:54 AM
Autometer made a product, called the Tri Alert. It had three inputs, and would work with electric gauges. You could set it so when the value was higher/lower than the set value it would activate the appropriate output.
So, you could wire in a warning light, buzzer, electric shock unit ;) or whatever to alert you when your oil pressure dropped or temps rose, etc.
They stopped making them recently, I think they came out with the Nexus gauges not long after.
CarlC
09-05-2007, 07:10 PM
You could also use the low fuel warning module used on 1st gen Camaros. It's easy to wire in.
CamaroAJ
09-07-2007, 12:08 PM
Fuel Safe also makes one, you'll have to look on there site for it. www.fuelsafe.com
whytry
09-10-2007, 08:47 AM
Where can one of these be found?
whytry
09-10-2007, 09:26 AM
nevermind, I found them on Ricks' site.
If I was not running stock gauges, how would I create one?
