View Full Version : Slipping A/C clutch
Mike Holleman
08-25-2007, 09:46 AM
I'm on my second clutch on the Classic Air system I put in my Tempest. The original one worked great for a season and then started squealing on start up and later all the time. I replaced the clutch several months back and it was fine but now it is starting to slip again. What could be causing this? It is properly shimmed and there doesn't seem to be a voltage drop.
Any A/C pros out there?
Mike Holleman
ProTouring442
08-25-2007, 10:57 AM
Honestly, it really sounds like a voltage problem. With the clutch engaged, check for voltage between the negative terminal on the compressor, and the negative terminal of the battery. I'm betting on a bad ground.
Shiny Side Up!
Bill
Mike Holleman
08-25-2007, 05:33 PM
I'll check that. Someone had told me that the system being overcharged could cause excess strain on the clutch. Any truth to that? I really need to get this corrected before heading to Pigeon Forge.
Gonna need my A/C.
Mike Holleman
ProTouring442
08-26-2007, 02:12 AM
Gonna need my A/C.
Mike Holleman
Not really... if it were too overcharged, the blow off valve would let go.
Shiny Side Up!
Bill
HILROD
08-26-2007, 05:49 AM
It can be overcharged enough to cause the clutch to burn up. That is a common problem. If a little freon is good, more is better.
formula
08-26-2007, 07:18 AM
Replace it with a 12" mcleod.
Hey, it'd be unique.
vintageracer
08-26-2007, 08:09 AM
If you are running a 134A system, the high side pressure can be critical. Overcharging will cause excessive high side pressure. This causes problems for the compressor and makes it harder for the compressor to turn.
I would definetely check my pressures with a gauge. Remember, it takes a lot less 134 to fill a system than R12. Since you have an aftermarket system, make sure it is filled properly per their recommendations.
Second, the clutch setup as mentioned above is also critical and you state this dimension is correct. You did not state the type of compressor however I would guess it is a Sanden. These compressors and clutch give VERY little trouble. Since a clutch costs damn near as much as a complete compressor/clutch combo, I would give serious consideration to replacing both this time. If you are running a GM A6 compressor that is a rebuilder from the Zone or somewhere like that, this is likely your problem. I have had very little luck with rebuilt A6 compressors from anyone. Particularly since most rebuilders do not replace that little ceramic seal that is hard to install and that seal is somewhat expensive. If you have an A6 compressor, spend the money and update to a Sanden compressor. You will be glad you did!
You should not be having this problem IF you have a Sanden compressor. Call Classic Air and bitch a little bit since they loaded you up with their system!
Mike Holleman
08-26-2007, 10:21 AM
It is 134A and a Sanden SD7. I installed it about three years ago. The clutch trouble began about a year ago. And the trouble started a few months after a recharge. It could well be overcharged. I'll have it checked as I don't do freon. Classic makes a nice system but they lost me when I needed the clutch and they only sold it with a compressor. Hot Rod Air had what I needed for about $80.00. I have since installed several of Hot Rods units with good results. Thanks for all the help.
Mike Holleman
ProTouring442
08-26-2007, 12:35 PM
While I'll agree that overcharging can cause excessive high pressures, my experience has been that overcharging with 134A usually causes pressures so high that the high pressure relief valve lets go the first time the car is driven in any real heat.
That being said, as the problem came about just after the system was recharged, I would have a look at it. Definitely check that ground as well though, as it still sounds like a ground problem to me.
Please let us know which it was, and if it was overcharged, what sort of high side pressures you were running, I am very curious!
Shiny Side Up!
Bill
72Z/28
08-26-2007, 02:33 PM
I have the same problem as well. I bought the car, and it came with the serpentine system, March Pulleys, and Sanden Compressor. The clutch was squealing or spining when reving the engine at high RPMs in neutral.
It does not make that noise anymore. Also, i noticed that it is out of 134A. It migh have been overchaged with 134A when it was squealing, not sure though..
Mike Holleman
08-26-2007, 04:16 PM
I ran a seperate ground direct from the battery with no change.
Hopefully I can get someone to put gauges on it this week.
Mike Holleman
ProTouring442
08-27-2007, 02:47 AM
Mike Holleman
Bummer.... Too mad you aren't closer, I'd invite you over and we could throw a set of gauges on it.
And you're sure it's the clutch that's slipping, and not the belt, yes? As the clutch is a metal to metal contact, they usually burn up when slipping.
Shiny Side Up!
Bill
Mike Holleman
08-27-2007, 04:39 AM
Thanks for the offer. Definately the clutch slipping. It's a March serp. system. It squeals as you try to bring up the Rpm's. It would burn up if I didn't shut down the A/C. I'm having a local shop check it today.
Mike
ProTouring442
08-27-2007, 03:16 PM
Mike
Cool, let us know what they find. I am very curious!
Shiny Side Up!
Bill
Mike Holleman
08-28-2007, 04:33 AM
It will be Thursday before they can service my A/C. I'm having the system evacuated and refilled with 24 oz. 134A as per Classic's specs.
The previous charging was done by a buddy at a local performance shop. I doubt he weighed the load. If the clutch still slips, I will have to guess that the damage is already done and just replace it. I did add a ground from the block to the compressor just to be sure.
Mike
ProTouring442
08-28-2007, 06:39 AM
Mike
I know this is frustraiting, but at least you have your head on, and are looking into things one at a time. You may also want to chec the voltage at the compressor if it's still slipping. Maybe the clutch isn't getting enough juice? I know in my original answer, I kind of took that for granted, something I know I shouldn't do! Just ask me about the time I cleaned and rebuilt the carbs on my Triumph Bonneville four or five times, sure it was running lean. It wasn't, it was an electrical issue. :banghead:
Shiny Side Up!
Bill
Mike Holleman
08-28-2007, 09:03 AM
We have all been there Bill. The voltage was the first thing I checked. Here again no change with a direct from battery 12 volt feed. I spoke with Hot Rod Air this morning and they suggested that the belt might be too tight? It's not.
Mike
KUL FIR CHICK N
08-28-2007, 11:57 AM
You're most likely overcharged. If you don't have a pressure safety switch in your system, you definitely need one. All systems should have one. There is no pressure relief valve in that system, so if you don't have a switch, you are likely to ruin your compressor, and possibly injure someone when a hose blows.
Also, check your fan. If its a clutch fan, make sure the clutch is good. If its an electric fan, it should be triggered by a "trinary" switch, which is a combination safety switch/fan signal switch. It is located in the high pressure line. There must ALWAYS be good air flow through the condenser when the system is on. Without the fan on, you can reach 400psi in about 15 seconds on a hot day.
Many shops claim to know what they're doing on an A/C system, but we often find that the "expert" A/C guy at the local shop is the one most likely to mess up your system, because he thinks he knows more than he does and therefore ignores the manufacturer's recommendations. Some shops also add oil when they shouldn't. Too much oil will have the same effect as overcharge.
Bottom line, you really can't do a good job of troubleshooting the system without a set of gauges on it.
It sounds like neither of your suppliers did a very good job of helping you troubleshoot your system.
ProTouring442
08-29-2007, 02:16 AM
Ah... I assumed it had a relief valve. Well, you know what they say about assuming, eh?
Mr Chick Fil-a here is correct though, if there is no relief valve, pressures can get out of hand very quickly. Especially with 134A. When we charged my father's car, there aboslutely no specs to go by (Firebird evaporator, Corvette compressor, Buick condenser, plus whatever lines). While charging to see, we watched outlet tempsas well as high and low pressures. It only took a very small overcharge to cause high pressure to zing past 350psi. It's my understanding that, on a 134A system, there should be gas pockets in the post condenser liquid line. With R12, this isn't so (hence the old sight glass systems).
Shiny Side Up!
Bill
Mike Holleman
08-29-2007, 04:48 AM
OK, There is a binary safety switch on the dryer. The twin 12" fans are switched on with the compressor. I didn't use a trinary because the fans are switched on the negative side by way of a relay as per Spals instructions. Just in case the clutch is already toast, Hot Rod Air has a new one on it's way to me.
Mike
Mike Holleman
08-31-2007, 08:54 AM
Alright the verdict is in. The clutch is not slipping at all. The squeal is belt after all. The A/C guy marked the clutch to show alignment and it did not move when the squealing was happening. He found the pressures right where they should be. Checked the amp draw on the clutch. Everything with the A/C was right on. The problem is that the March serp system only allows about one third contact area on the crank pulley. That is where it is slipping. This belt has maybe 5,000 miles on it. Looks like I need to change the belt with oil changes. That sucks.
Mike
rohrt
08-31-2007, 09:06 AM
maybe you could put some track bight on the belt? Belt squeel is a pretty common problem and it sure is annoying.
ProTouring442
09-01-2007, 02:51 AM
Is there room to engineer an idler pulley to make more of a wrap? If you can increase that wrap to at least 1/2 of the surface, it should stop slipping.
Post a pic of the setup, I'm sure someone here can suggest a way.
Shiny Side Up!
Bill
Mike Holleman
09-01-2007, 06:01 AM
If the attachments work, you'll see very little room for an additional idler. The belt contacts just about 1/3rd of the crank pulley. This belt was installed just before the 06 Power Tour. Has about ten thousand miles on it. I guess changing belts every other year is not too bad. At least I know now that the squealing is not destroying a clutch. And that my A/C is setup right.
HILROD
09-01-2007, 11:56 AM
I have had bad luck with the March powder coated clear pulleys. They slip and squeal. On V belt pulleys I've just sanded in the belt grooves and cured the problem. On the surpentines I've masked off the outer parts and sandblasted lightly on the belt area. On another car I stripped the whole pulley and repolished the faces, per customer prefferance.
Mike Holleman
09-01-2007, 02:13 PM
That is a good suggestion. I'll try it. I too have had very bad luck with Aluminum v belt pulleys. They flat wear out in short order. The best fix I have found for them is steel pulleys.
Mike Holleman
KUL FIR CHICK N
09-03-2007, 07:22 PM
Most other manufacturers hard coat or chrome their aluminum pulleys for durability. I believe March claims hard coat, but you can't hard coat in clear. Its either dark brown or black only. Plain aluminum pulleys will never hold up. As they wear, the groove geometry goes away and they're ruined. BTW, true hard coat anodize is in the HRC 50-70 range, that's tool steel hard. Your best bet may be to buy a new pulley and have it hard coated.
ProTouring442
09-04-2007, 02:08 AM
Where could you get something like this done?
Shiny Side Up!
Bill
KUL FIR CHICK N
09-04-2007, 03:36 AM
Most anodizing shops can do it. The trick is finding one that will do your part when they're running another job so you can avoid a minimum charge. You should be able to get it done for under $50.
MonzaRacer
10-07-2007, 09:29 PM
Actually March was clear anodizing the pulleys from the info that I got but they had some outside sourcing for clearcoating after polishing, A friend of mine bought several sets and we found the clear was on part of the serpitine area, and the powdercoating does slip bad.
AS for belt squeal double check your tensioner and make sure it has belt contact in the first 20 percent of let down or the spring tension.
This usually means the first 1/4 to 1/2 in of letdown.
You should, to have proper tension, only be able to just barely slip the belt over the grooves or one of the smooth pulleys or you will get slipage, been there ,seen that.
Also so far I have found the Good year ggatorback belts just palin suck on the aluminum setups.
My favorites are Gates and the Kelly Springfield belts from Autozone, the AZ belt is made as a run in type belt ratherthan a semifinish belt like others and the Gates also leave a better run in finish too.
