Tyson A
08-22-2007, 07:56 AM
I'm trying to get my rearend figured out.
First I should give you a run down blue is what I have, black is soon to come.
69 camaro
dse tubs,quadralink,subframe connectors
345/30/19s and 265/35/18s
Art Morrison sub
Alston FAB9 housing
Looking at LS7 with approx. 625 to 675hp and the torque should be in that range also.
4L80E 1st gear ratio is 2.48 if that helps
Moser online axle tech formula shows that 31 splines would be good with their formula giving me 5860 possible ft. lbs. of toque and their specs are:
Each axle should be able to handle all of the maximum torque your car can produce. That way it is practically impossible to break an axle because you have at least a 200% safety factor.
To achieve maximum performance you should use the smallest axle that will safely handle the torque your car produce.
When I called Moser they did not recommend that setup and said I should go with a locker and 35 splines.
I called DSE and they recommended a truetrac and 31 spline axles and said they use that setup on all their 9" rearends.
So whats your opion
This car will be 90% street 10% track
69 camaro
Art Morrison sub
Alston FAB9 housing
So whats your opion
