View Full Version : Edel Carb
Z06killinSBF
08-21-2007, 12:59 PM
So I currently have a 600 man choke Edelbrock carb on my 289. The car basically falls on it's face when I floor it. Also has an uneven "pur" to it so to say when hoding at a steady RPM out of gear. Kinda coughs and jumps around alittle. After about 2500rpm it runs like a top at WOT. Carb is box stock. Any tuning suggestions or if you need more info let me know. I'm sorry if this is vague.
Randy67
08-21-2007, 05:45 PM
It sounds like the carb is a bit too lean. I had a similar problem years back with a Edel 750, just had to richen up the rods and jets 2 steps I believe, according to the chart in the instructions that came with it.
MarkM66
08-26-2007, 11:08 PM
Read the owners manual. Sounds like a simple pump arm hole change could help.
Z06killinSBF
08-27-2007, 03:03 AM
Yea, owners manual long gone. I have a few other tuning issues to attend to. I need to check the gap on my plugs and also run some carb cleaner through the carb. It has been sitting for awhile but I just figured it would clear up. After I get the baselines check, I'll look into doing the mentioned methods. Thanks guys, I'll try to work on it tonight.
MarkM66
08-27-2007, 03:09 PM
Look on their website. There use to be a full owners manual, and a bunch of tuning tips.
What hole is your pump arm in now?
