View Full Version : Lincoln rear calipers same as Bear???
Moabdude
08-20-2007, 04:43 AM
I heard that people using Lincoln rear calipers with parking brake included. I even heard that those are the same ones Bear is using.
Is this tru and if yes, what year lincoln must I search for?
fast Ed
08-20-2007, 05:34 AM
I believe that Baer uses the 1LE Camaro or 88 - 96 Corvette HD option calipers for many of the rear brake kits. Those are the aluminium PBR single piston calipers.
cheers
Ed N.
jknight16
08-20-2007, 06:39 AM
No, they're definitely not the same. I'm sure others will chime in with more specifics but I can only tell you that the Granada/Versailles brakes that are often sought after are very different from what Baer uses. If after you do your research you decide to go the lincoln route, I have a complete set of new/rebuilt calipers, rotors, brackets, lines, etc, that I can sell you...cheap. In the interest of full disclosure, the set I have are difficult to match with front discs, due to the 3"+ piston area on the rear brakes. Not likely to match up well with your Wilwoods, unless you're running some kind of dual master cylinder or something....
JK
neki67
08-20-2007, 09:38 AM
You've got mail!
René
