I recently aquired this 76 Vega wagon in a trade for an engine. Considering they came from the factory with rust, this one is virtually rust-free.
I have a good running 400 small block, an extra set of 17" ROH Snypers, tons of space and tools, the know how, and the time this winter, Hmmmmm............:hmm:
Ok join the H body club man.
I am working on my 77 Monza SOOOOO if you need any good ideas and some tips pm or email me at
[email protected].
There is a brake upgrade to get 5 lug and make it so you can install big brakes.
www.v8monza.com (http://www.v8monza.com) is also another good site.
Get the V8 motor plates to bolt the v8 in and Bob had true replaceable motor mounts and the adapters for installing larger brakes.
I am sending an upper controlarm to Mark at SC&C to have some good ones made.
If it wears vented rotors stock we can up grade.
With the adapters scrounge up a set of 98-up s10 Blazer 2wd spindles then you can upgrade with adapter plates, I can dig up the website so you can get a hold of the guy who makes them, and then upgrade to brakes in the Corvette range.
I'll dig out my CD I have saved all the parts, prices, places and such on my project. I know its here somewhere.
Anyway for a interim up grade you can simply use first gen S10 spindles and Raybestos BruteStop pads, very nice base combo.
On the fronts your only going to get around a 17x7 maybe 17x7.5 and a 20540 or a 215 45 maybe a 205 45 in front but for the back with finesse you may beable to get some descent rubber in it.
also if the lower control arms mounts measure out right(I gotta go find my notes) you can slide a S10 2wd or 4 wd rearend under it pretty easy.
i am working on the parts to install a bolt in 3 or 4 link for an Hbody with or without Air Ride.
I should have the measurements and a part number for Air ride Technologies ShockWaves here real soon.
The rear suspension will be fairly simple and I have had to scrap one prototype as it was more cutting than I wanted.
Now unless your going to cut the crap out of it so be it but if you want bolt ons and stuff that will work keep in touch.here is a pic of my yellow 77 and my new blue project.
anyway good luck and keep in touch and if you want to actually talk to me on the phone pm me and i give you my home number.
Lee Abel
AFTERMARKET PERFORMANCE
