osdmike
08-14-2007, 07:08 PM
Hi!
I have Wilwood 340-1287 Forward Swing Mount Dual Master Cylinder Brake Pedal with Balance Bar.
Pedal Ratio is 7:1
http://www.wilwood.com/Products/005-PedalAssemblies/002-FSMP/fsmdmcbp/index.asp
I contacted Wilwood about MC size,and they recommended 7/8"
bore in front and 1" bore in rear.
http://www.wilwood.com/Products/006-MasterCylinders/003-HVAMC/index.asp
Calipers are Forged Billet Dynalite 4 piston 1.75" , both front and rear .
Usually You would go 1.38" in the rear , but according to Wilwood there shouldn´t be a promblem when using the bias bar.
Front discs are 10.75" / .81" .
Rear discs are 12.19" / .81" .
Brake lines are 3/16 all the way , with Russel Braided Stainless Steel Hose (DOT) connected to the front calipers.
The problem is ,that I have to press brake pedal very hard , to make the car stop.
To lock up the front wheels, I have to press really hard.
I noticed that Wilwood also have a 3/4" master cylinder available.
Would 7/8" in the rear , and 3/4" in front help ?
What am I missing here ?
Any suggestions ?:dunno:
"Osdmike"
Pedal Ratio is 7:1
"Osdmike"
