View Full Version : !st gen front back spacing w/wilwood brakes
69ozz
08-13-2007, 10:22 AM
Hi all, I have the wilwood brake/hub package on my 69 camaro. I was wondering what others have done for backspacing? Its a stock subframe with 2" drop front and rear. I know most use an 8" rim with 5.00" back space. I was going to go with 8" rim with 5 3/8" back spacing. I measured after i changed brakes/hubs and my treadwidth was 3/8" wider on each side. I was wondering what others did with the same combo? Thanks, Greg
Damn True
08-13-2007, 11:33 AM
Get the brakes installed then take measurements.
There are way too many variables for anyone to say anything remotely accurate.
6'9"Witha69
08-13-2007, 12:40 PM
I run 17x8 with 4.5" bs on the front. same wilwood package (it seems).
baz67
08-14-2007, 07:53 PM
5.375 is too much BS. The spacing that Nick has is more the norm. You mentioned you have a 2" drop front. Is that by spindle or spring. If it is by the spindle you will never get your wheel to fit because it will hit the steering arm.
68/CamaroFL
08-15-2007, 08:20 AM
I Orderd my Boze wheels with the Wilwood brake package Front and the sizing is 18 X 8 / 5 on 4-3/4 Chevy with 4.3/4 Back spacing (Front)
ProdigyCustoms
08-15-2007, 09:14 AM
The easy way to figure backspace is to deduct 3.25 from the rim width. So if it is a 8" rim, go with 4.75. If it is a 8.5, go with 5.25
