View Full Version : Well I thought I was ready to drive it..
ITLBTU
08-09-2007, 09:21 AM
I finally finished the Camaro... or so I thought. For those who don't know what I did. I replaced the whole front suspension with a bunch of components that Tyler from ATS recomended:
ATS tall spindles, Global West uppers, and lowers, C5 brakes, Baer trackers, GW sub frame connectors, a new Lee steering box, a new master cylinder and all new Moog components. I might have missed something, but I think thats it. I also dropped in a Keisler 5 speed tranny with a hyd. throw out bearing. I had a TH 400. And to top it off, I also dropped in a G-Bar set-up from Mark at SC&C. I also put a 3" Magnaflow exhaust, and new Stahl headers. All of these vendors were quite helpful and I am quite pleased with everything... This morning I took the Camaro to work and it is running like crap. Grrrr I thought I was going to be able to enjoy it for a little while. I haven't driven it in almost a year. I hope it's just a simple carb rebuild. I will try to get pics posted soon...
got_hp?
08-09-2007, 02:39 PM
hey, atleast it looks great! gotta look at the bright side sometimes. hope ya get the bugs worked out.
MSchu
08-09-2007, 03:16 PM
Are you running spacers/adapters with the 4th gen wheels? If so, what size?
brownz
08-09-2007, 03:18 PM
looks like some chevy guys at your work too looks good
70TWO NOVA
08-09-2007, 03:25 PM
Love the Wheels
MSchu the front spacers are 2", and rear are 1.25". I got mine from Vette Brakes (http://http://www.vbandp.com/SearchResult.aspx?CategoryID=62). You can get them on ebay also. The camaro wheels are 17x9 and with 245 40/17 front and 255 40/17 rear.
70TWO NOVA
08-09-2007, 03:29 PM
sorry if the first link didnt work. Here it is again; Vette (http://www.vbandp.com/) Brakes
ITLBTU
08-09-2007, 04:02 PM
I'm running 2" spacers all the way around. I got them from skulte.com. :cool:
70TWO NOVA
08-09-2007, 04:06 PM
oh yeah, youve got the ATS spindles. Im still runnin stock.
novanutcase
08-09-2007, 07:55 PM
Fix it FAST!!!!
That thing is too purdy to not be driving!!!:bananna2:
John
67SSDan
08-09-2007, 08:16 PM
Very nice car! I agree... fix it fast, that thing needs to be driven!
Dan
ITLBTU
08-10-2007, 09:05 AM
Thanks! It does look good from 20'. I first bought it when I was 19 and had it painted when I was 20... I'm 42 now... Here's what it looked like 22 years ago...
ViperBlue68
08-10-2007, 10:05 AM
looks good even 22 years ago! I've always been a fan of Rally Wheels..car would prolly look good with some 17-18" rallys as well
67SSDan
08-10-2007, 12:01 PM
Hey man, 20+ feet is how most people will see it! :naughty: When you're driving it, I mean.
ITLBTU
08-22-2007, 11:49 AM
Well I got the front end aligned. I don't know how it really handles though, because the rear tires rub on the inner fender well when I turn sharp. I also need to grind more off the bump stop tabs that are welded to the lower GW control arm. My turning radius is still way too big. I also found a bad spark plug, and a corroded spark plug wire and socket in the cap. The wire broke when I tried to clean it(the dutch in me...) So I bought one plug and a new set of MSD wires, cap, and rotor. I only bought one plug because the head has some tiny cracks in the cumbustion chamber that let the cooling system get pressurized when I get on the throttle, so I wanted to see if I could ceramic seal them. I have a set of al. Brodix heads that I can use, but they are pretty much bare. It still has a slight miss though. I did a compression tes and they were pretty close. The lowest was 210, and the highest 235. Most were right at 225. I guess I'll check the valve adj tonight.
