Give it a shot with alt unplugged if that doesnt work try this.
first check you centrifical advance and I use stock weights with lightest sprring I can get it to return to rest posistion with.
Then set it at about 14 to 16 egrees of initial timing and idle it down and adjust the mixture too the highest manifoold vacuum possible with smooth idle.
Now hook vacuum advance up to manifold vacuum, and readjust the idle speed as low as it can in drive.
yuo can also readjust or finetune the mixture with vac advance hooked up too.
If you run out of idle speed screw you may have a bad vacuum leak or the secondaries may be open too far and you will need to remove car(if holley) and flip it over and close the secondaries some more.
also you may need to drop the powervalve size too.
This setup will let it idle much better, get better mileage and let the butterflys to be closed as much as possible.
On the outside chance you have too large a cam and can close the blades enough to get idle mixture to affect running then you may need to drill a small hole(I start with 1/32") in the primary throttle blades, towards the front, centered between the shaft, outer edge and side to side.You can also keep upping this till you can get it back into the idle circuit effectivly but dont go over 3/32, if it need s to be bigger then you may need to open the secondaries more as long as its not a 4 hole idle setup carb(ie 4 idle mixture screws.
Good Luck and if you need any more help pm or email me at
[email protected].
Lee Abel
AFTERMARKET PERFORMANCE
