GUS68
08-02-2007, 08:10 PM
Hey guys!!! It's been a long time since I have posted on here! Life happens. Any way... I know this isn't you usuall 68 camaro stuff but rear suspension is suspension right? Soooo...... I dont know if any of you are familiar with 62 chevys but they are coil spring rears with 2 lower control arms slightly angled in and with the lower spring mount welded to the top of the arm. Originaly there is only one upper arm on the pass side of the center section pointed straight ahead. Then just a cross linkto center the rear attaced to the driver side frame accross to the pass side of the axel. I guess some of the 409 car from the day had a 4th upper link on the driver side just like the one on the pass side. There is a place to mount this 4th link on the frame, so thats what I did by using an upper arm from another car. I have boxed the upper and lower controll arms and installed all new poly bushings. My question is, after I did all of this, the car STILL wheel hops!!! What do I need to do?? What did I do wrong?? What didn't I do?? I just want the hop to go away!!! Make the bad man STOP!!!!!
