View Full Version : What do you do with a damaged Q-jet.. How about make it a double pumper. Oh yes I did
LowBuckX
08-02-2007, 12:20 AM
First before anyone tells me I wasted my time-- Its My time and you shouldnt concern your self with it. With that said
Introducing The
Quadra-pumper
I did this because well why not. If it dont work it will look cool on the wall of shame..
First the bottom. I used a fire victum 600 holley as a organ donor.
I used an Aluminum drop to buld the Pump body. I copyed the Holley as close as possible. It will have the newer check diaphram not a check ball like older holleys
Here is he top of pump housing I made a large fuel well or bowl if you will.
Side view of pump
here is the top with the vent tube and o-ringed cap
rear shinny
Ive just always had this what if in my head for a long time. So I had a damaged q-jet here so I just ran with it. lol
LowBuckX
08-02-2007, 12:21 AM
Fuel is being fed in to the well by a port I drilled bettween the rear butterfies. The top of the well is at fuel level so it should gravity feed itself.
Obviously its not done I will be filling alot of what was milled off back in. the big hole behnd the barn doors will be filled in with a formed plate.
And alot of sanding will follow.
jc70chevy
08-02-2007, 07:04 AM
thats crazy i love it lololol i would have never thought of that haha
83hurstguy
08-02-2007, 09:38 AM
are you going to make it mechanical secondaries as well?
LowBuckX
08-02-2007, 10:11 AM
That would be a yes. :candle:
6'9"Witha69
08-02-2007, 11:26 AM
You have some cool ideas or at least ways of implementing them. Imagine the guy who thinks you have a Qjet and gets smoked!
I like seeing what you come up with.
Chad-1stGen
08-02-2007, 02:02 PM
Looking forward to when you try mounting that thing on a car and if it works!
83hurstguy
08-02-2007, 04:00 PM
Sweet!
LowBuckX
08-02-2007, 09:19 PM
Me too.. lol Like I said if it dont it will look cool on the wall. I have no dreams of it transforming my car into a wheel stander just by bolting it on. Just some fun at the bridgeport.
LowBuckX
08-06-2007, 11:29 PM
Not sure why this was moved to a tech section it was a outhouse type subject not a tech article.
