View Full Version : Best natural gas garage heater
Einstein1
12-31-2004, 01:26 PM
I have just finished running a 3/4 natural gas line to my garage. I am looking for a natural gas heater. Where I am putting my gas heater I also have a duct to vent it, does anybody have any recommendations of brands or where to get a nice heater for my garage. It is about a 3 car garage. Any input is greatly appreciated.
einstein
Quick GN
01-01-2005, 02:18 PM
I just finished installing a Hot Dawg garage heater. I only have a 2 car garage so I got the 45,000 BTU unit but they go up to 100,000BTU for larger spaces. It was very easy to instal and works amazingly well I would highly recomend one. I see them on Ebay alot or just google Hot Dawg and I'm sure you will find a distributor. Oh ya they are also cetified for residental use (the only heater I found that was).
JMarsa
01-01-2005, 08:06 PM
I grew up with a propane fired Reznor unit heater in my dads garage that never had a day of trouble (MI use) so when it can time to purchase one for my 900 sq. ft garage with 10 ft walls and cathedral ceilings I chose the same. I have a natural gas 75,000 BTU UDAS model (also certified for residential use, as is Sterling I believe). This is my first season with it. It's quiet, safe, (separated combustion) and powerful. It throws air that can be felt over 26ft from the unit. I purchased the unit directly from a wholesaler (~$1000 and paid $300 to have it mounted (I stubbed off the gas line and had the unit pre-hung in it's final position) and all duct work done to code.
Bear in mind that my unit is nearly twice as expensive as a non combustion chamber sealed unit, but when I thought of whether an extra $500 was worth risking my $30K investment and my car and antique boat inside, I chose the safest route. I can paint or work with combustibles with a piece of mind.
Here's some links I saved when researching prices:
http://www.poly-tex.com/pages/accessories/heaters.html
http://dev.obatadesign.com/clients/Empire/pdf2003/RES-COMPrices2003.pdf
http://www.littlegreenhouse.com/accessory/heaters.shtml
http://www.kennspenns.com/heating/reznor.html#price
http://www.djsonline.com/reznor_UDAS_Separated_Combustion_Unit_Heaters.htm
Regards,
--JMarsa
Smoke'm
01-01-2005, 08:48 PM
over size your unit...its nice to be able to bring the room up to 75deg quickly to paint stuff and have it lay down nice....
CAMAROBOY69
01-03-2005, 08:22 AM
I installed a Furnace out of a trailor that works way better than I even need. It was natural gas but i converted it to propane. The furnace was only $150.00. I talked about it in this thread. Heated garge for the cheap guys (https://www.pro-touring.com/forum/showthread.php?t=2423&highlight=heated)
I can heat my 20x22=440sq garage from 30degrees to 65degrees within 5 minutes. I realize yours is bigger but this works soo well and so cheap. Just an idea.
