Tim_in_NC
07-30-2007, 06:30 AM
I'm using a kit with Dual Nozzles ... I really don't want to install in my carb hat unless it's needed ...
Would there be any issues with installing both nozzles side by side in my elbow where my bypass valve is located? I would install them pointing down or pointing up ...
Will this cause any issues with the bypass valve that you can think of?
Or do you guys think I should just install them in the under side of the carb had ... firing upward?
thanks
thanks
