View Full Version : Wheel Guru's Needed!!!
Patrick
07-29-2007, 02:02 PM
I have a set of Boze Hi Octane wheels that I must run a 5/16 spacer on the front.
The spacer that Boze sent me is a generic aluminum spacer (the kind you see at any parts store...drilled to fit anything). The spacer has a ton of movement on the hub, so it is nearly impossible for me to have it centered when I tighten the wheel.
Here are my questions...
1) How much effect does the spacer not being centered have on wheel balance?
2) Does any one make a hub centric wheel spacer as small as 5/16"?
68sixspeed
07-29-2007, 03:37 PM
I remember seeing 'propper" machined wheel spacers recently-- jegs sells Baer spacers. I can't recall the other place I saw them, but if it hits, me, I'll post again.
Patrick
07-29-2007, 04:10 PM
I found that Skulte and a couple of other companies will make them as small as 5/16" . I was really curious to see how much impact being off center so close to the center point of rotation would have on wheel balance.
Boesch
07-29-2007, 04:38 PM
You should be able to position the spacer as you snug it up. Just finger tighten the lug nuts and then push the spacer so that it's centered.
07-29-2007, 09:15 PM
I like to use a couple daubs of seam sealer. Its sticky enough to hold it but not thick enough to cause a mounting or balance problem.
Bozeforged
07-30-2007, 09:30 AM
Patrick,
Give me a call I can help you out.
Zak
Toll Free # 866-634-4626
www.bozeforged.com (http://www.bozeforged.com)
