View Full Version : Question about C5 calipers
Jasons68
12-29-2004, 05:39 PM
I just put on C5 brakes using the touring classics bracket and GMpartsdirect calipers and parts. My question is this...Is there supposed to be something holding the pads on the calipers? I put the pads in the abutement brackets and slid on the caliper, but the pads seem loose. There is nothing on the pads like on the C4 pads to hold them in? There is no way they are going to fall out or anything, but it seems like there may be an extra part I need.
Jason
Q ship
12-29-2004, 09:50 PM
Do you have the thin metal shims between the abutments and the pads? GM pads come with the shims included, or Napa sells them seperately. Heres a link. (http://www.napaonline.com/cgi-bin/ncommerce3/ExecMacro/NAPAonline/search_results_product_detail.d2w/report?prrfnbr=28502201&prmenbr=5806&usrcommgrpid=98214509) There are 3 shims per side, 1 at each end of the pad located on the abutments and 1 that clips into the caliper.
The pads are not "attached" to the calipers at all, though.
Jasons68
12-30-2004, 07:03 AM
Thanks for the reply! I do have some shims with adhesive on one side that came with the pads. I just wanted to be sure there were no springs or clips I was missing.
Do the shims go on the inner or outer pad? Or both?
MarkM66
12-30-2004, 07:48 AM
Jason,
What did you pay for those calipers at gmpartdirect.com? Can you give me a part number?
Jasons68
12-30-2004, 08:09 AM
If I recall the calipers were about $80 each. I am at work right now :banghead: so I cant get the part number. I'll look later when I get home. Also the drilled and slotted rotors were pretty cheap as well $40-$50. They were a few dollars cheaper than the regular rotors.
Ill post back later with the part numbers
Jasons68
12-30-2004, 02:56 PM
Mark,
left caliper-10052203
right caliper-10052204
Q ship
12-30-2004, 09:05 PM
Do you have the shims marked #2 and #11 on this drawing? (http://chris96ws6.mtfba.org/c5brakes/Brake%20Brackets/Cailiperexplode.PNG) Those are the ones you need, they don't have adhesive so.....
Jasons68
12-31-2004, 03:08 AM
Q,
No...I dont have those!! :pat: Thank you for your help!
Happy New Year!
MarkM66
01-01-2005, 09:05 AM
Jason, thanks for the part numbers.
Did you calipers not come with the #2 and #11 on the diagram?
indyjps
01-01-2005, 12:27 PM
do you have part #'s for lh and rh rotors
thanks
Jasons68
01-02-2005, 06:35 AM
Indy,
I can get those part #s for you later Im at work again!
Mark,
No those parts do not come with the calipers. The calipers come with nothing, except the banjobolt and bleed screw. I wish they did, but I did order them from napa.
MarkM66
01-02-2005, 03:58 PM
So you didn't get "loaded" calipers?
jeffandre
01-05-2005, 04:41 AM
Does anybody know if you can get #3 buy itself? I already have the others. If not, does the NAPA part # include all 6 total? Thanks,
69boo307
01-05-2005, 07:52 AM
I've put 5k miles on my C5 setup with no shims...didn't know I needed them! I havn't had any problems, but I guess I'll go pick a set up.
Q ship
01-05-2005, 05:37 PM
Jason, glad I could help. :cool:
Jeff, #3 is the outer pad assembly, so I assume you mean the shim that is on the outer pad? I don't know where to get them, but I assume they're out there-I bought Hawk pads and they were attached, do your pads not have them?
Oh, and the Napa kit is per side, you need two kits(at 20 bucks a pop) per car. I puckered a little at that, but couldn't find another source(GM only sells them with their pads). I figured I got it back by using Napa's C5 rotors -$25 each, still cracks me up that you can get 13" directional rotors that cheap. Rockauto has them even cheaper!
Jeff, I've been meaning to email you, I'll be in touch soon.
jeffandre
01-05-2005, 07:02 PM
Brian,
I meant part #11, sorry about that! I may just go with the side shims if I can, they are the rear brakes if that makes any difference as to importance of that 1 middle shim. Email is changing to
[email protected]
Jasons68
01-06-2005, 04:33 PM
Indy,
Sorry for the delay...I had computer problems and have been trying to fix that (actually bought a new computer). I cant seem to find my list of part numbers right now, but I promise I will post back when I find them.
Jason
