View Full Version : Alcohol compatible Fuel Injectors for 350 TPI
oddball383
07-09-2007, 07:02 PM
Has anyone found any injectors that could work with E85 and fit in a 1989 TPI 350 small block chevrolet.
Z-man
07-10-2007, 10:18 PM
Any injectors should be compatible. Almost all gas has alcohol in it anymore.
Your ECU may have to be reprogrammed to work with E85 (depending on your type of O2 sensor) and your engine would have to be modified to get it to take advantage of E85 properly.
oddball383
07-11-2007, 09:13 AM
Z-Man What kind of EFI are you using and what is the brand name of the injectors you use.
Z-man
07-12-2007, 08:34 PM
I'm running a Holley C950 system. My injectors are 65lb Bosch - they came with the FI unit.
