View Full Version : TPI Injectors
A friend of mine have these injectors for sale. Will they fit my TPI intake?
I know some ford fit Chevy TPI Intake
Ford Racing B-302 30# "Red Tops" 0280150756
Johnny Blaze
07-07-2007, 11:55 AM
They should fit.
Thanks,hope these will be good for 400hp plus....
Olav
Is it ok to use the C5 filter/ regulator for my engine swap. Seems like a simple solution. Or.......
Olav
EFI69Cam
07-10-2007, 05:14 AM
Olav
The pressure will be higher than what those injectors are rated at.
Also the C5 uses a returnless fuel system. If you have a TPI your reg is on the fuel rail.
Can I plug/ cap the outlet from the fuel rail and use this. Many use this for LS engines up to 450hp plus.
andrewb70
07-10-2007, 08:05 AM
No. The LS1 engines operate at 58.5psi. That is what the C5 filter/regulator are set to. The older systems were at 43.5psi.
Technically the C5 fuel suystem is not returnless. The return line runs from the filter/regulator back to the tank.
