View Full Version : Fast xfi to Digital 6 hook up
dplenzig
07-01-2007, 08:26 AM
I was wondering how to hook the Digital 6 to the xfi harness. I am using the dual sync distributor and it connects to the hall effect connection. This efi thing is new to me.
Daren
MrForce
07-01-2007, 09:02 PM
The points trigger wire of the XFI (usually white) goes to the white wire of the Digital 6 box. Nothing on the distributor goes directly to the ignition box on an EFI setup.
EFI69Cam
07-09-2007, 10:17 AM
Daren
Also make sure your ignition type is set to sink points or something to that effect. You don't want GM ESC or Ford TFI output.
Fuelie Nova
07-09-2007, 03:06 PM
Your ignition needs to be set to IPU and the white wire is correct. I just went through this same situation today. You also want to use the 50* timing method if you are running a dual sync and sequencial injection.
Tg
