View Full Version : Third Gen Camaro Pics! Anyone?
Chevrolaine
06-26-2007, 06:01 PM
Where they all at? I've tried the search and get nothing.:hmm:
Certainly there's a few of you out there.
rich_fbodySS
07-10-2007, 06:25 PM
Here's my 92 RS. It's got a blown up rearend right now (again).
Gonna work on it next week, now that the 72 has gone to the body shop.
I bought it new in '92. Car has 265K on it.
99 Corvette wheels, 300 HP crate motor, Tremec TKO.
-Rich-
07-10-2007, 06:46 PM
...here is ours. its a track car now due to its lacking of smog equiptment.
brownz
07-11-2007, 05:30 PM
-Rich-
wow didnt like the c5 wheels till now those look bad ass:twothumbs
Chevrolaine
07-11-2007, 06:02 PM
-Rich-
I'm likin the green paint. Not seen to often.
slowcamaro
07-12-2007, 03:22 PM
Heres mine
TPI Monte SS
07-12-2007, 04:43 PM
-Rich-
Sweet looking car!!! Rich, which bellhousing did you use to mount the TKO? I'm weighing options for when I eventually replace my T5.
69bigblock
07-12-2007, 05:25 PM
Here's a friends car
rich_fbodySS
07-13-2007, 06:12 AM
I bought the whole kit from Mike Forte's a few years ago.
http://www.fortesparts.com/
His kit uses an adapter plate (1" thick) that fits between the stock bellhousing and the trans (rotates it vertically). Also has spacers that fit between the crossmember and floor to make room for the bigger trans. He also supplied the correct speedo adapter for my 3.73 gears. It's been beaten on a bunch over the last few years and all I've done is change the oil in it and replace a clutch now and then.
(used to destroy t-5's regularly, banging second gear).
-Rich-
TPI Monte SS
07-13-2007, 07:12 PM
Thanks for the info Rich, I will look into that when the time comes! I'm using a bellhousing from an '83 V8 F-body, that's why I asked. I was hoping it was a relative bolt-in for you, and that the crossmember or driveshaft didn't need to be changed. Seems like I'll be in OK shape if I go that route. Good luck repairing your car!
heavy_chevy29
07-14-2007, 03:56 PM
i too am a proud owner of a third gen camaro. its a 1984 z28. im the fourth owner of it and ive owned it for about 6-7 years now. i never stop working on it. its got a whole laundry list of stuff done to it, most of witch ive done myself. ill highlight some of the key features:
scott shafiroff 434sbc (576hp 582ft-lbs)
built 700r4 with 3400 stall converter
sunset orange metallic paint with silver ground effects
currie 9inch rear
c4 vette brakes up front
11inch currie disc brakes out back
spohn performance tubular suspension front and rear
harwood 4 inch fiberglass hood
boyd cottington smoothie II 17 inch wheels
and thats just some of what is done to it. i love it and it always turns heads. check out my photobucket site for pics
http://s54.photobucket.com/albums/g105/heavy_chevy29/?sc=1&multi=10&addtype=local&media=image
CamaroAJ
07-14-2007, 06:36 PM
92' i used to have, had 41k on it when i got rid of it.
https://static1.pt-content.com/images/pt/2007/07/92camaro-1.jpg
platinumgta
07-18-2007, 08:16 AM
here is my 85 Z
platinumgta
07-18-2007, 01:02 PM
and my gta I just sold...
Chevrolaine
07-18-2007, 03:36 PM
Is that the one the guy on thirdgen.org bought?
Drop Dead gorgeous car!
Johnny Blaze
07-19-2007, 12:07 PM
Heres mine.
Old motor,
New one
WELTERRACER
07-20-2007, 03:42 PM
Here is my 1984 camaro... I converted it to a Z-28 using 1985 ground effects and bumpers.. added a 92 wing and stuck a crap load of money into the car over the past 9 years.. (worlds biggest money pit)
I will say this,, it is fast.. with around 700-750hp i just added a smaller supercharger pulley and a extreme velocity carb bonnet and it runs on pump gas!
WELTERRACER
07-20-2007, 03:53 PM
Here is two more pics of the engine..
355, 8.9-1 comp
CAT forged rods
Cat forged crank
Trw Forged pistons
Dart Pro 1 heads (ported)
Crane cam 234/244 duration,.523/.544 lift
1.65 harland sharp roller rockers
Dart cool can intake
Holley 750 carb
ATI P-1SC supercharger
Large intercooler
Procharger bypass valve
Holley fuel pump
1 5/8 headers and single 3inch exhaust
T56 6 speed
Aluminum flywheel
Stock rear end with street/strip diff and 3.73 gears
17x9.5 centerline wheels with drag radials on the rear
GEN_X
07-30-2007, 08:36 AM
These are a few from my comp. The blue one has had massive mods done to rear to fit a 18X12.5 w/ a 325/35-18
BOTTLEDZ28
08-17-2007, 07:35 PM
here is a few old pics of mine. I have since tossed the cowl hood and wheels. I now have an SS hood and NO wheels. But that will change soon as I got something up my sleeve:
https://static1.pt-content.com/images/pt/2007/08/z282-1.jpg
https://static1.pt-content.com/images/pt/2007/08/z281-1.jpg
https://static1.pt-content.com/images/pt/2007/08/z28-1.jpg
Kenova
08-18-2007, 05:44 PM
Do you have any pics of the mods?
I've never been big on the third gens, but I do like the roof line of the convertibles with the roof up. I wouldn't mind having a rag top with a custom formed and permanent steel roof. How nuts is that?:geek: :rolleyes:
Ken
GEN_X
08-19-2007, 01:39 PM
http://www.thirdgen.org/techboard/body/386427-phase-i-complete-now.html
That link has the complete buildup of the car.
mikey0oo
09-28-2022, 04:05 AM
Hi I have a bbc in my 3rd gen camaro what front spring will sit it up high nicely.
