View Full Version : Napa Syl-Glyde for Lube on Injector O-Rings?
TheMonkey
06-17-2007, 02:14 PM
would Napa Syl-Glyde work to slip injectors in manifold & rails? i bought that for brakes, it must hold up to heat well, and help preserve any rubber parts?
thx, Scott
Goatman
06-17-2007, 04:16 PM
What ever happened to vaseline? Its all I ever used....
Samckitt
06-17-2007, 04:37 PM
I had always heard not to use Vaseline, was told that it deteriorates the rubber. I use either lithium grease, or tranny fluid.
tumper93
06-20-2007, 12:22 PM
I have used it many times on injector orings along with seal lips etc, works great and won't damage the rubber.
MonzaRacer
07-02-2007, 05:40 PM
Anything petroleum based will work. When I worked for Firestone we had a product called slider, petroleum based with teflon so I doubut it would hurt but anything slick helps.
camcojb
07-02-2007, 05:54 PM
I use brake cylinder assembly lube, much better than normal lubes.
Jody
Fuelie Fan
07-03-2007, 07:10 AM
tranny fluid is what i was told as well
GBodyGMachine
07-03-2007, 02:30 PM
On every car I build or put injectors in I use Sylglide. Great stuff.
Jeff
