View Full Version : Which bowl is for which on a M/C?
gsxrken
06-14-2007, 11:09 AM
On a stock 4 wheel disc master cylinder, such as one from a 1996 V6 Mustang that I used, does it matter which ports are used for the front or rear brakes? I assume it does not, but since I regularly see the rear bowl going to the front lines, I did it that way. I would suspect that it doesn’t matter, and that front/rear bias is dealt with in caliper piston sizing or proportioning valves.
Now I’d like to know if that was correct.
Skip Fix
06-15-2007, 02:42 PM
Generally the larger bowl supplies the front as they have larger piston volumes to supply than rear systems.
jaybee
06-18-2007, 08:21 AM
There are some applications for a stepped-bore m/c, but it's extremely rare and I can't tell you what uses it.
