View Full Version : 1970 camaro
jc70chevy
06-14-2007, 07:04 AM
was wondering if any one knows the biggest tire and rim package i can put under my camaro with out any modification and if zr1 wheels will fit or what i need to make them fit thanks:banghead:
DriverzInc
06-14-2007, 08:47 AM
I typically put an 8" wide wheel on the front and a 9.5" wheel on the rear with a 4.75"BS front, and 5.75"BS rear. The ZR1's are all 9.5" if I remember correctly, with a high offset, which will then require you running about a 1.5" long adapter. Here's a photo of my 70 I'm selling. It has 8's and 9.5's with a 245wide tire on the front, and a 275 on the rear. Hope that helps. Feel free to call or email if you have any questions.
https://static1.pt-content.com/images/pt/2007/06/1970Camaro005-1.jpg
jc70chevy
06-14-2007, 01:39 PM
Thanks For The Advice I Love Your Car Nice I Remember A Super Chevy Article Sayin That On Our Year Camaros With 17 Inch Rims You Can Get A 315 40 17 On It With 6 Inchs Of Back Spacing I Just Want To Find That Article To Double Check My Info
DriverzInc
06-14-2007, 03:17 PM
At 6" of BS, I wouldnt run much more than a 295 wide tire, especially if your car is lowered any.
zbugger
06-14-2007, 04:20 PM
Normally, as far as I've seen, 5.75" backspace is the most to run on the rear. Actual MAX sizing is 17x9.5 front with 5.5" backspace running 275/40 tires, and 17x11 rear with 5.75" backspace running 315/35 tires. You do have to watch for the seat belt bump in the front of the rear wheel well and roll the fender lips though. In front, you're gonna most likely see rubbing on the front sway bar, and possibly the outer lip with a chance of the rear of the wheel well on some cars. It's worse on lowered cars. Most 2nd gens run 17x8 with 4.75"-5" backspace up front running 245/45 tires, and 17x9.5 with 5.5" backspace and either 275/40 or 285/40 tires. I hope this helps you. If you need any more help, the many of the guys over at www.nastyz28.com are running the sizes I just mentioned.
jc70chevy
06-21-2007, 01:15 PM
Thanks You Guys Decided To Go With Hopster Rims 17'' 9.5wide And 8 In Front
