View Full Version : Truck touring...
xx_ED_xx
06-07-2007, 12:38 PM
Hi guys,
Been awhile, i sold the firebird and now own a 04 silverado short bed std cab 2 wd v6 5 spd. I just got my 20 inch wheels and tires today. next pay check is 2/4 drop for it. Future plans include wilwood 16 inch brake upgrade. 14 inch rear upgrade. viper t56. 9.3 liter BBC. I am pretty much tryin to build a pro touring truck. If anyone else has had any experience doing trucks any suggestions would be appreciated. :drive:
Nate K
06-07-2007, 05:35 PM
I had a v8 ranger for a while and it was hard to get it to handle well. First thing I would recommend is to make sure your spings are designed to help the handling and not just lower the truck. I had some cheap lowering spings and changed to eibach spings and it was way better. Another thing is to get the motor back as far as you can I set mine into the firewall 3" and that made a big difference.
xx_ED_xx
06-09-2007, 04:01 PM
Cool i appreciate the input. I plan on for now using the stock springs til i get the big block lined up for it. The drop uses spindles and hangars and i retain the facotry springs front and rear.
MonzaRacer
06-09-2007, 08:44 PM
ED got to www.ridetech.com. If you want the truck to handle check out pics from the street challenge. you can go low, ride sweet AND burn corners and still keep a load carrying capacity.
NO NO NO dont do the spindles I just tried to align one with drop spindles, talk about a mess. I couldnt get enough camber for some reason.
Try air ride its so much better.
Lee
xx_ED_xx
06-13-2007, 12:17 PM
:bicycle:
I called air ride. 6200 for a complete setup. Nice stuff. Thanks for the info
xx_ED_xx
06-25-2010, 05:20 PM
ED got to www.ridetech.com (http://www.ridetech.com). If you want the truck to handle check out pics from the street challenge. you can go low, ride sweet AND burn corners and still keep a load carrying capacity.
Lee
My mcguahys spindles worked out good. Now I got the same drop with a stock spindle thanks to the heavy 8.1 in it.
xx_ED_xx
07-09-2010, 06:21 PM
Just bought this for the truck
Is there anything i could improve on this? I am thinking double adjustable shocks and maybe a watts link.
Lets see some full on shots.
Shockwaves would solve your problem. You could get rid of those shocks and it will really clean it up under there.
I vote watts.Watts links are bad ass.
xx_ED_xx
07-10-2010, 06:42 PM
Yup they make a bolt in for this truck
ArtosDracon
07-10-2010, 10:32 PM
That is a nice Watts, I say go for it.
xx_ED_xx
08-19-2010, 01:35 PM
I am trying to fix the aero of my barn door on wheels. I plan on running the truck at maxton at the end of october. I am going to make a belly pan, block the grille, a wierd custom bed cover, and some kind of rear diffuser. I already have smaller mirrors oh and some kind of front splitter. Any other suggestions. I also bought some c6 z06 calipers to do a 15 inch front 14 rear brake setup on the truck.
I also bought these for the truck to clear the brakes etc.
Samckitt
08-19-2010, 09:09 PM
What wheels are those? I like 'em!
xx_ED_xx
08-19-2010, 10:51 PM
Agio sport FMB 22 x 9.5
You're lucky, you have a few options for watts links. Unlike me and my Tahoe, hah, I dont have any options, well besides a weld-in which is what I'm eventually going to be doing.
Not quite sure what you can do to make your barn door break through the air besides what you already have planned. Sounds great and will look even better.
That brake and wheel combo is going to be sick. Though not sure if its the ideal set up for any kind of track duty.
What do those 22s weigh?
Regardless, we need to see some updated pics of this bad boy.
xx_ED_xx
08-23-2010, 12:09 AM
Yeah when I take leave all these parts are going on... and of course lots of pics and videos to follow. Not sure if anyone here goes to maxton but it would be nice to have an event or something there, I am trying to find a video girl to go with me..
xx_ED_xx
04-03-2012, 04:14 PM
Been awhile figured I would give some updates
https://static1.pt-content.com/images/pt/2012/04/423730_379701125374575_100000040736749_1-1.jpg
https://static1.pt-content.com/images/pt/2012/04/DSC01107-1.jpg
https://static1.pt-content.com/images/pt/2012/04/DSC01105-1.jpg
https://static1.pt-content.com/images/pt/2012/04/IMG_20120112_202427-1.jpg
https://static1.pt-content.com/images/pt/2012/04/IMG_20111030_182735-1.jpg
https://static1.pt-content.com/images/pt/2012/04/IMG_20111103_135724-1.jpg
https://static1.pt-content.com/images/pt/2012/04/DSC00345-1.jpg
https://static1.pt-content.com/images/pt/2012/04/DSC003261-1.jpg
https://static1.pt-content.com/images/pt/2012/04/DSC02073-1.jpg
https://static1.pt-content.com/images/pt/2012/04/DSC02072-1.jpg
Modified a stock intake to flow alil more air
https://static1.pt-content.com/images/pt/2012/04/DSC01127-1.jpg
https://static1.pt-content.com/images/pt/2012/04/DSC01126-1.jpg
https://static1.pt-content.com/images/pt/2012/04/DSC01130-1.jpg
https://static1.pt-content.com/images/pt/2012/04/KGrHqYOKpEE4kWg1OoBOU8Oq4hg48_3-1.jpg
https://static1.pt-content.com/images/pt/2012/04/DSC00941-1.jpg
https://static1.pt-content.com/images/pt/2012/04/DSC00937-1.jpg
Lil turbo action
https://static1.pt-content.com/images/pt/2012/04/scan0002-1.jpg
https://static1.pt-content.com/images/pt/2012/04/scan0001-1.jpg
https://static1.pt-content.com/images/pt/2012/04/DSC01113-1.jpg
https://static1.pt-content.com/images/pt/2012/04/DSC01112-1.jpg
Truck now has full ridetech airride
c6 z06 brakes all the way around 15 inch rotors front 14 inch rear
faceplated t56
rebuilt motor with ported heads 505 inch zz502 cam
Made a custom intake will upload pics later
rear mounted a tv8101 turbo
more to follow when the inet comes back up in afghanistan...
xx_ED_xx
04-14-2012, 06:10 AM
updated pics
