View Full Version : Opinions: Aeromotive A1000 - Blown Carbs on Gas
Bored&Stroked
06-07-2007, 04:32 AM
Hey Guys: I am just getting ready to setup my fuel system for a blown 392 Hemi, running dual BG 650 blower carbs. This is a hotrod engine - so it will see mostly street, with some drag fun every once in awhile.
What I"m pondering is an Aeromotive A1000 pump, with a 13204 presssure regulator/bypass setup.
I'm also wondering if I should purchase the electronic fuel system controller -- that steps down the output for slow speed cruising.
The car will have a MSD trigger and a 7535 MSD box on it.
Thanks for your help and opinions -- most appreciated!
Steve1968LS2
06-08-2007, 05:27 PM
The controller will help the pump live longer and run cooler. I had good luck with the A1000 but other have burnt them up.
Is this going in the tank? (submerged)??
Anyways my new tank uses a Bosch elec pump so I will have an A1000 for sale soon. For my power level the A1000 was sorta overkill..
Oh, make sure you vent the tank enough.. that pump can pull a TON of fuel.
