dannyho
06-06-2007, 12:56 PM
I've been running through my options for ECUs and I've come across one. It's along the lines of a megasquirt setup, but it does a lot more. its called vems (www.vems.hu (http://www.vems.hu)) The only issue I see is that it doesn't necessarily suppose dual widebands, only one for tuning. It has the capability, but noone has gotten around to updating the software and firmware. This means that in the future it most likely will get that feature.
But my simple question is do you really need dual wideband UEGOs?
I understand it's going to tell you if one bank is running learn compared to the other but aren't they close enough to where it isnt going to be a problem? My engine bay is pretty uniform in shape and size, so I would expect heat to be around the same from side to side. I'd be using a single plenum intake with an elbow. Probably upgrading to a turbo setup later down the road, but for a while it will run NA.
what if I had dual EGT's, would that make up for it?
