View Full Version : VA heater control valve placement
dplenzig
06-06-2007, 06:14 AM
I have a GenII set up fpr my 69 camaro and was wondering where some of you are putting your heater control valve. There is not much room under the dash. Maybe some pics?
Thanks, Daren
TxDanno
06-08-2007, 07:11 AM
I too would like to see some pics of the gen II setup hose routing, heater control valve placement on the first gen camaro. I'm in the process of installing and those hoses look like they're gonna be a tight fit.
Bow Tie 67
06-08-2007, 06:58 PM
I made a u shaped bracket with flanges and welded it to the firewall, mounted the va unit fabricated a new vent block-off and routed the hoses through the cowl were the heater blower motor normally goes. The solenoid will be mounted off the heater motor hole block-off plate under the passenger fender. Here is a pic of the heater from the inside.
https://static1.pt-content.com/images/pt/2007/06/223238456-1.jpg (http://www.fquick.com/garages/viewgallery.php?action=viewimg&id=38456)
